Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Gumba11's Avatar
Porsche Crest Wheel stud question....
I recently purchased a set of Fikse FM10's for my 77 Turbo. I ended up switching the wheel spacers front to rear to correct the rear wheels being out a little too far and the fronts being a little too inward. With the spacers switched the wheels are a perfect fit.
Can I do the same thing with the wheel studs? I now have minimun thread engagement on the front wheels and the studs stick out of the open end of my lug nuts in the rear. If I am able to switch the studs out this should take care of the issue correct?
Thanks for your thoughts here. I know its a strange question, Im hoping I worded it well enough to be understood.
............................................Chris
77 930 "P Zilla" 3.2 Litre w / EFI conversion
Old 06-14-2007, 10:54 PM
dewolf's Avatar
If you measure the stud length front and back you should be able to work out if your idea will work. I would think that you'd be correct though.
In Heaven… the mechanics are German, the chefs are French, the police are British, the lovers are Italian and everything is organized by the Swiss.
In Hell…the mechanics are French, the police are German, the chefs are British, the lovers are Swiss and everything is organized by the Italians.
Old 06-15-2007, 02:27 AM
Crotchety Old Bastard
RarlyL8's Avatar
Sounds like a plan. If the spacers and studs were correct before as a set they should be correct if moved as a set.
Old 06-15-2007, 04:52 AM
kellcats521's Avatar
I would buy longer studs for the front, and keep the rears as they are by using open ended lugs. Or, if that's not an option, buy all new studs. Re-using wheel studs will in the best scenario work, but I personally wouldn't be too confident that re-installed studs wouldn't slip/spin in the hub at some point.
I did a similar swap when I went to BBS wheels in that I put the 1" rear spacers on the front (with new studs). I had to go to a 2.0" spacer on the rear, so I kept the original studs and used a spacer that bolts to the hub using them.
Pat K
87 930
Old 06-15-2007, 06:01 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
