Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
What Do You Guys Think Of This Cooler?
It seem like a good idea... Anyone running it?
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 06-24-2007, 07:12 PM
GO DAWG GO's Avatar
Fabbed My Own
BMAN,
I bought one of those coolers and plumbed it myself. The installation looks just like that photo except mine is slightly lower and I fabbed a shroud to deflect the heat blown off the cylinders.
I lowered it so it was in direct airflow, but not so low it would be damaged from a speed bump.
Yesterday, it was warm in Rancho and had the car jacked to replace a crossover tube exhaust gasket. I had the car running for a while and took some temperature readings with an infrared thermometer. Delta temp between the inlet and outlet was ~ 8-10 degrees. You must not accept that data as accurate. The cooler works by heat transfer, so it would be very inefficient with the car static. I didn't own my turbo last summer so I don't have any history of expected summer temps. But I think if you can get 5-15 degrees cooling it will be worth it. I bought the Cooler for $40 and opened the 3/8 ntp hole to 3/4 pipe thread and bought the fittings from TMR in Orange Ca. It cost about $90 dollars for everything. I think the kit is $230 at Performance Products. I cut my S tube and used it also. It has ~1 inch inside diameter.
Bob
1 bad 930
Old 06-25-2007, 06:06 AM
Thanks for the info... I'll have to think which way I want to go.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 06-25-2007, 01:42 PM
David's Avatar
If if was me, I'd pass on that cooler and put the money towards a large front mount cooler.
2014 Cayman S
2011 Cayenne Turbo
Old 06-25-2007, 02:56 PM
GO DAWG GO's Avatar
I totally agree, But in my case the oil lines are not there because I have that 935 type rear fender ram air cooler config. I would like to have a front cooler too. Elephant lines are expensive. I was thinking of fabbing some aluminum tubes to feed the cooler up front. That little cooler does help and worth it if it was a little cheeper.
Bob
1 bad 930
Old 06-26-2007, 04:51 AM
Save your $'s and go with a front valance cooler. Ask me how I know.
Old 06-28-2007, 06:45 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
