Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
E-85 sippin drunk
turbobrat930's Avatar
for those with EFI...show me your wiring....
I would like to see how you guys have routed your wiring, placed and mounted your computer, relays, etc... I will be wiring mine this weekend...hopefully if the unit shows up. I already have an idea what I am going to do, but would like to see some pictures of how others have done it... Thanks Brad
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 06-26-2007, 10:20 AM
David's Avatar
I don't have any pics of my EFI wiring on this computer, I'll look when I get home. I used a 47 pin Duetsch bulk head connector through the rear bulkhead behind the rear passenger side seat. I installed the ECU under the passenger seat. My ECU relay is in the front trunk by the fuse box and I used the stock fuel pump relays.
Here's a pic of the new and old engine harnesses (no EFI wiring in this harness). I was able to eliminate a few wires .
2014 Cayman S
2011 Cayenne Turbo
Old 06-26-2007, 10:57 AM
E-85 sippin drunk
Hey, david, thanks for the reply. I will be doing that to my engine harness this afternoon. It is amazing what you can get rid of, since we don't have CIS.
I was actually looking for pics of say, a group of relays, or the EFI control box itself and how it is displayed with all of the associated wiring. I was thinking of getting a piece of aluminum, and mounting everything to it, routing all of the wires in a neat fashion. Just wanted to see how everyone else out there has theirs mounted...wanted to get some ideas... Thanks for the pic... do you have any more? Brad
Old 06-27-2007, 11:04 AM
David's Avatar
Here's a pic of the installed engine. The bulk head connector is near the top middle of the pic. I haven't put on the shrink wrap so you can vaguely see the 47 wires going into it. A picture of my relays wouldn't show much since I used the stock fuel pump relays and my ECU relay is just laying near the fuse box.
I got some brackets for my ECU that bolt to the floor board and my BAP sensor is next to it on a simple aluminum bracket.
I need to pull the seat again since I forgot to write down my ECU serial # , so I'll snap a pic then.
2014 Cayman S
2011 Cayenne Turbo
Old 06-27-2007, 03:04 PM
why the orings on the tb? not seen that before
Ben
Current project 73 914-6 Gt project rusteration 2.4
Reproduction 914-6 oil tanks, 1-5/8" 914-6 heat exchangers source call 2623647426 or email mbconsulting21 @gmail.com
Old 06-27-2007, 03:26 PM
E-85 sippin drunk
The O rings are there from the factory. They help seal the joint between the I/C and the TB. If you didnt have them, there would be boost leaking between the two metal joints....
Old 06-27-2007, 03:39 PM
E-85 sippin drunk
damn, David, that looks very nice... I would be interested to see your pic under the seat... thanks....
Old 06-27-2007, 03:41 PM
David's Avatar
Actually, I didn't know what was in that groove from the factory, but it looked like two orings would fill the groove nicely so that's what I used .
2014 Cayman S
2011 Cayenne Turbo
Old 06-27-2007, 03:49 PM
E-85 sippin drunk
Mine had one thick orange o ring in it from the factory... but if two smaller ones do the trick...then cool
Old 06-27-2007, 04:06 PM
the 3.2 intake TB never had orings as the groove was for the afm boot to "seat "against
Ben
Old 06-28-2007, 04:40 AM
David's Avatar
Here's my ECU and BAP: (that flash sure makes the carpet dust show up )
2014 Cayman S
2011 Cayenne Turbo
Old 07-02-2007, 04:39 PM
Gumba11's Avatar
Does anyone have a factory diagram for 77 930 ROW car? It would be a great deal of help for the stage I am in with my EFI conversion.
Thanks and sorry for thread robbing but it was fairly on topic.
77 930 "P Zilla" 3.2 Litre w / EFI conversion
Old 07-03-2007, 11:42 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
