7.0:1 > 11.3:1
Wastegate spring identification
I have a 7 5/8" long wastegate spring from a Porsche wastegate. Does anyone know how much boost it is intended to produce?
My factory 6 3/8" spring produces .8 bar/12 psi. The longer spring has exactly one more winding, is the same dia and same wire size.
Old 06-26-2007, 06:51 PM
wcc wcc is offline
wcc's Avatar
I'm curious about this too. I think the only way to really tell is to install it and use an air compressor to see when it opens. But I'm don't know.
So, free bump....
Bill
Old 06-27-2007, 04:13 AM
7.0:1 > 11.3:1
Bill, I tried this with both wastegates hook to a common line from a regulator. The longer spring seemed to crack the valve open about 1.5 psi over the shorter spring/wastgate, so .9 bar. I also measured the wastegates to see if the cap and compressed length of the spring were the same, and everything was identical. Perhaps it's a .9 bar spring, just seems like an odd increment.
Old 06-27-2007, 07:21 AM
Gotta Jibboo
BSiple's Avatar
Send a message via AIM to BSiple
Thats the cool thing about the TIAL springs, they are painted a certain color, so you know whats what...
2003 996TT
1992 964 Turbo (sold) Holy crap are these expensive now!
1986 911 Cabriolet (sold)
I don't know why I do the hillbilly things I do.
Old 06-27-2007, 01:00 PM
wcc wcc is offline
wcc's Avatar
That's how I would have done it. I'd say you have a .9 bar spring there. Is kinda odd, but this test doesn't lie. I wonder if these are the same psi numbers a 1 bar gets so it's really a .9 they just call it a 1 bar cause that's the next incement. I've never heard of a .9 bar spring either. The performance catalog I have right here says the 1bar is 20% over stock and the 1.2bar is 33% over stock.
Bill
Old 06-28-2007, 04:53 AM
rsscotty's Avatar
I tested a 6 3/4 inch spring on the dyno @ 1 bar.
The 7 3/4 inch spring tested @ .7 bar
Old 06-28-2007, 06:17 PM
