Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Manassas, VA
lucittm's Avatar
Intercooler Wiring Modification
Fellow Enthusiasts,
During a routine intercooler clean and inspect (my first one), I noticed that someone had spliced the two wires together that lead to the Boost Pressure Switch (white) and the Boost Pressure Transmitter (brown).
Has anyone else seen this? What would be the motivation to do this? I disconnected the offending and unauthorized splice modification and have noticed no difference. Of course, I don't have the proper tachometer, so I cannot monitor boost pressure.
Anyone have a spare 1991-1994 turbo tach with on-board computer (OBC)?
1991 964 Polar Silver Metallic Turbo Coupe
Old 06-29-2007, 08:01 PM
E-85 sippin drunk
turbobrat930's Avatar
Instead of getting an OEM tach with the boost guage inside, why not get the mechanical boost guage that replaces the clock?? Them you dont have to rely on an electronical sending unit. You can have a hose that connects the boost guage directly to the I/C, so you know exactly how much boost you are running....
here, follow the link: http://www.nhspeedometer.com/911/custom_design/1.htm
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 06-29-2007, 08:53 PM
Manassas, VA
lucittm's Avatar
North Hollywood Speedometer
Brad,
Thanks for that link, I was looking for it earlier to call them about the mod to the oil temp gauge that provides the numbers instead of just the lines.
Old 06-29-2007, 09:41 PM
E-85 sippin drunk
no problem. I had them redo all of my gauges in my car, including raising my speedo to 200MPH, offseting my tach, custom colors and new glass and bezels. I also had several more VDO gauges, and they do those to match as well. Excellent quality.... highly recommended!!
Old 06-30-2007, 03:19 AM
Manassas, VA
lucittm's Avatar
Lightbulb Myster Solved
I think I answered my own question. A few days ago I was really standing on it and the car shut down like it hit a brick wall when I got to about 6000 RPMs. I read in the PEC that the function of the boost pressure switch is to remove the ground from the fuel pumps if the switch detects an over boost condition.
I have extra springs in my waste gate, so I probably was over 1.1 bar. The shocker though, was the dramatic reduction in acceleration. It came on so fast I was literally thrown forward and both hands nearly came off the wheel. Foolishly, I tested it once more and it was the same as the first time.
I guess the PO had this experience and crossed the wires to prevent the switch from opening and removing the ground signal (it is normally closed). I would not think the wire to the pressure transmitter (for the OBC boost guage) would be enough of a ground, but I guess it is.
Too bad the boost pressure switch is not adjustable. I will leave the modification off the car, but what fun is 1.1+ bar of boost if you can't use it?
Mark
Old 07-06-2007, 06:56 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
You only have to ground the overboost wire. Not sure why he did both, but you found your answer.
Old 07-08-2007, 05:19 PM
Manassas, VA
lucittm's Avatar
930Rocket,
That is the funny part. The PO did NOT ground the boost pressure switch or the boost pressure transmitter, he simply wired them together. Imagine the letter X , that's what the pair of wires looked like.
Weird huh?
Mark
Old 07-09-2007, 07:41 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
