busteif's Avatar
Turbo Boost Loss
last year a local mechanic replaced the clutch on my 1976/930 and since I have not felt the pull or boost the car use to have before the clutch. I checked for air leaks and the intercooler among other things. however, when he put the engine back in the car he ripped a hose off and said this is the heat hose and would not affect anything else???? I posted a picture of it. can some one tell me if affects anything. the other picture is the intercooler back side toward the back seat notice there is no screw holding the unit down like there used to be.
comments and feedback please.
Old 07-04-2007, 01:16 PM
mark '87 930's Avatar
I can't quite make out the pictures (position wise) but the first one does look like a heater hose and would not affect performance, ,just your heat in the cabin.
The second one I don't recognize, although if that is the IC piping to the turbo, it doesn't seem to be seated all the way onto the rubber gasket/o-ring.
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 07-04-2007, 07:05 PM
Send a message via AIM to Chuck Jones
That is the hose that takes heat from your engine and routs it to your passenger compartment.....but regardless of whether it affects the mchanical performance of your car...you paid someone to fix your car, not destroy another working part of the vehicle's functions. To me, that sort of work is unacceptable. I sincerely hope he's willing to go back in there and make it right.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 07-04-2007, 07:25 PM
busteif's Avatar
Boost
thanks for input and feedback to both.
Old 07-04-2007, 07:49 PM
7.0:1 > 11.3:1
Your intercooler needs to be held down properly otherwise the pressure created by the turbo will escape by pushing the intercooler off the throttlebody. It appears this is the intention of the missing bolt.
In the first picture I noted you have a twin sparkplug engine which is unssual for a 76. Can you tell us a little more about your car?
Old 07-04-2007, 10:56 PM
Have you pulled the piping to inspect the "O" rubber rings that help provide the seal between the pipe parts.. The tech might have messed one of them up. If the seals arent tight you will get blow by.
1987 930 -Guards Red
2001 740I sport Blk
2011 F-150 supercrew Blk
2014 X3 2.8 white
"What goes around comes around..."
Old 07-05-2007, 06:53 PM
What kind of gauges do you have in the car? If you have pressure loss wouldn't that show up on a gauge?
Black 1985 Carrera ~ Whale Tail - Gone but not forgotten
2013 Boxster - Wifey Car
1969 Karmann Ghia - Next in line for restoration
"Driving in its most beautiful form"
Old 07-06-2007, 09:38 AM
busteif's Avatar
boost
thanks all,
O rings are good. found the screw and put it back on...it was a b... but got it done. I will test drive Sat.
thanks.
Old 07-06-2007, 08:51 PM
