Porsche Junky
mede8er's Avatar
Beware....The Bucking....
I came suddenly....silently....
It came as I was having a little tet a tet with a 350Z down an uncrowded rural highway...
Done toying, I downshifted and waited for the boost to propel me away from the Z when BAM! The Bucking....
Today was my first chance to really explore the issue...there is definitely a correlation between a suddenly lean condition showing on my WB A/F meter near full boost and....The Bucking....but the car runs great otherwise
To be continued.........
1986 930 RUF equipped
Old 07-07-2007, 02:42 PM
A fellow Pelacanite
NathanUK's Avatar
Overboost switch ?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 07-08-2007, 04:30 AM
Manassas, VA
lucittm's Avatar
See my post above
It's called "Intercooler Wiring Modification"
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 07-09-2007, 07:58 PM
peritus's Avatar
Oh, too bad you weren't in that 3.6 conversion you sold to me... you'd have blasted by that Nissan - like when the Enterprise accelerates to mock 10 in Star Trek next Gen... as if you forgot Hee Hee
James
91 Black on Balck 964 C4 (DD)
82 Metallic Red SC 3.6 Varioram (sold)
Old 07-13-2007, 12:48 PM
Porsche Junky
mede8er's Avatar
Hehhehheh....I smoked that Z even with the overboost prob....
Undoubtedly my wastegate is sticking....havn't had time to investigate further...
Old 07-16-2007, 05:18 AM
Wo ist die Rennstrecke?
DonE's Avatar
Re: Beware....The Bucking....
I have to say - your first sentance had me a bit scared to read any further.
But I did....
Old 07-16-2007, 04:59 PM
Porsche Junky
mede8er's Avatar
But I did....
Hehhehheh...well...it was pretty scary...
Old 08-02-2007, 01:40 PM
BlkBird's Avatar
What makes you think it is the wastegate?
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
Old 08-17-2007, 12:01 PM
Stephen B's Avatar
Did you fix the problem? My car was doing the same thing - bucking violently when coming off of full boost/throttle. Ended up being a torn wastegate diaphragm. It was maintaining the correct boost pressure at WOT, but once I lifted the boost would spike and trip the overboost sensor. A quick way to check: Disconnect the wastegate boost signal line at the intercooler and blow into it. if air passes thru you have a leak.
Old 08-20-2007, 09:05 AM
beepbeep's Avatar
It will often leak trough the valve stem even if diaphragm is sound. Wastegate should be "blown" from venting hole on the top...not on the bottom. When "blown" from the top, there is no other way for air to escape but trough the diaphragm.
Thank you for your time,
Old 08-20-2007, 01:23 PM
