Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Thread damage on #4 Cylinder
I can't believe what has happened... I did a full tune up and when I tried to install the #4 spark plug I could only get it to turn 3-4 turns and it just get real tight. I did all of the other one by hand first and then tighten them down with a ratchet with no problem.
My question is has anyone used this http://www.back-tap.com/ on the #4 cylinder? I need to know if it will fit being 6" long.
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 07-10-2007, 05:22 PM
fastfredracing's Avatar
I have never used this tool, but I have a spark hole rethreading tool that I use sometimes when I get into a jam. The two big problems you will run into will be getting the tool aligned properly, and not getting metal chips into the combustion chamber. A little grease on the tool may help the shavings adhere to the tool instead of falling into the chamber.
Good luck
1976 930( peru red usa) ,1980 euro sc, 1974 914. 1997 M3, , 2004 Duramax 3500 quad cab dually . 2004 2500 HD Gas 1989 Yamaha xt 350. 2004 Turbo Pepperwagon, 1976 Chevrolet C 60 Rollback towtruck. 2006 x3 a few old tractors, and tons of tools
Old 07-11-2007, 12:27 PM
Well the good thing about this tool is it works from the inside out so anything that comes loose will come up with the tool. My only problem is getting the tool to fit being 6" long. I had to order it so I should have it by Saturday.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 07-11-2007, 04:48 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
