Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Removing muffler/cat from turbo?
I have an 83 turbo that I tried taking the exhaust off after the turbo. I could only get at one of the four nuts.
Can anyone tell me the procedure for doing this? Do I need to take off the valance or bumper?
Thanks-
Craig Backer
Old 07-19-2007, 09:38 PM
Crotchety Old Bastard
RarlyL8's Avatar
If you haven't done it before (and have made or purchased the right tools to get in that tight spot) you will likely need to remove both. It will make things a LOT easier. Try removing the valance first and see if that works for you. If not then remove the bumper.
Soak those nuts good overnight with your favorite liquid wrench.
Old 07-20-2007, 04:55 AM
wcc wcc is offline
wcc's Avatar
Try this tool out. I'm planning on using this when I get around to replacing the muffler, turbo, etc... Then use a tap/die set to chase the threads before install. Of course you can never go wrong listening to RarlyL8's suggestions on here....
EDIT: (forgot the link)
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_34573_34573
Bill
Old 07-20-2007, 05:27 PM
A fellow Pelacanite
NathanUK's Avatar
Unfortunately if you cannot get a ring spanner around the nut you will not get a nut splitter around the nut either.
Those nutsplitters are excellent for removing headers though.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 07-20-2007, 11:29 PM
RarlyL8's Avatar
The way I read the original post the problem is not that the bolts are siezed but that Craig cannot get to the bolts. Correct?
Old 07-21-2007, 06:31 AM
Yep
Old 07-21-2007, 09:24 AM
Automotive Monomaniac
Emission's Avatar
I took off my valance first.
1986 - 930 Coupe / 2016 - BMW X5 xDrive35i / 2015 - Volkswagen Golf TDI 6MT / 2018 -Porsche 911 Carrera 7MT
Old 07-21-2007, 01:22 PM
When I pulled off my whole exhaust system I started with the muffler and worked back. There was a unique two nut connection on the back side of the turbo...each of the back two nuts had a welded metal band between them. I didnt re-install them.. they were too rusted..nice thing though... they braced themselves as you back out the bolt.
Brian you know if porsche sells the connected two nut bracket? my local P dealer didnt have the part.
1987 930 -Guards Red
2001 740I sport Blk
2011 F-150 supercrew Blk
2014 X3 2.8 white
"What goes around comes around..."
Old 07-22-2007, 02:11 PM
I was actually completing this same job myself today... just installed Rarly's zork tube. Hands down the easiest and least frustrating method is to remove the bumper. Other than having to disconnect the accordian thingies on either side its a real quick and painless job.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 07-22-2007, 02:32 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
