e p slick's Avatar
930 pump amp draw
Anyone know what a 930 fuel pump normal amp draw is? Thanks - EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 07-21-2007, 02:31 PM
Looks like they vary from 7-10.5 amps for the lower volume pumps as fitted by Porsche up to 15.5 amps for the motorsport pumps like the 044.
'77 S with '78 930 power and a few other things.
Old 07-22-2007, 05:47 AM
magic930's Avatar
I just tested mine today. I get 4.5 amps at the rear and 5.3 at the front. This is in line with the bentley manual, anything under 6amps is OK, both pumps should be running for the test. By the way the easiest place to check this is at the fuse panel, two wires go into a single fuse . Just disconnect a single wire and jump it here with your test equipment then swap wires for the other pump.
Old 07-22-2007, 02:55 PM
