Question Pumped-up 915 clutch?
915 Power clutch kit seemed to deal OK with stock 930 power.
Unscheduled rebuild and restrained bolt-on goody frenzy ensues. Seemed just fine during break-in, made about 395 HP/350 ft/lbs (crank) when we checked the AFRs.
Seemed just fine for a while longer, too.
Now the clutch is obviously not happy and is polishing the flywheel with less provocation each time. It's got to come out and soon.
I want to pull the trigger on buying parts in the next few days, but I'm undecided what to put back in (although I'm leaning towards a Sach competition cover).
What you guys with 915's and > 300 ft/lbs torque running for a clutch setup, how much (if any) difference in streetability is there, how long are they lasting you and how much power/torque is your motor making ?
Thanks for any help!
'77 S with '78 930 power and a few other things.
Old 07-21-2007, 06:22 PM
Crotchety Old Bastard
RarlyL8's Avatar
The Sachs sport clutch is really nice for a street car. I'd put another one in. They don't like drag racing but niether does the 915!
Old 07-21-2007, 07:16 PM
I have a centerforce dual with around 400hp and 375T. The
pressure plate has 33% more clamping force than stock. I
don't care for the disc. It takes a lot of foot pressure. I
wonder about my cable breaking. I really need a hydralic
clutch with that pressure plate. It seems that with kevlar
clutches you get a lot of chatter. They are on or off.
Old 07-21-2007, 07:23 PM
Cool, thanks.
Brian, do you have a part # for the Sport clutch? Any specs? (I can probably get the latter with the part #'s...)
Is it a complete kit or an uprated plate? I'm told Sachs do a pressure plate they rate @ 350 ft/lbs, and I'm wondering if that's the same as you're referring to.
The power clutch had an original # (for the kit) of 3000961101, which apparently references or supercedes the following parts:
91511691100
91511600116
91511600127
91511601122
Must look up all the part #'s...
Jess, thanks for your reply too - I was told (by a competition clutch guy) that the 225mm Sachs 915 organic friction plate is rated (by Sachs) @ 600 NM, or about 442 ft/lbs. I was considering trick friction materials until I heard that...
Another competition clutch guy told me that all ratings quoted by Sachs have a 20-25% margin built in. (He was talking specifically about pressure plates in that instance, mind you - but seems like a fair bet it's across the board)...
KEP told me that their Stage 1 kit (which they rate @ 417 ft/lbs) uses the stock Sachs friction plate with their pressure plate.
One of the clutch guys I spoke to laughed when I mentioned the 930 motor and the Power Clutch, said "yeh, that won't work" and told me that the Power Clutch is a stock 915 pressure plate, and they just cherry pick the top 10% of the batch into the Power Clutch boxes (like Harley did for Cafe Racer motors in the 70's)... So there's apparently a pretty fair chance you could buy a stock Sachs clutch kit and end up with one with an identical rating to a Power Clutch...
Seems to me a pressure plate rated @ 350 ft/lbs with a 25% margin will hold up to 437 ft/lbs, which seem to be a good match for the stock friction plate.
I like off-the-shelf stuff, but I don't want to have to get a gym membership to change gear...
Old 07-22-2007, 07:20 AM
So what did you end up buying? How do you like it?
I myself am going to replace the clutch in my supercharged 911 carrera (1986) $340 HP. Too much power for standard clutch.
I drive on the street and rarely go to track events. I was thinking the Sachs Sport clutch might be good, but ive heard good things about Spec stage 3 clutch, and Kennedy. The Centerforce duel friction clutch sounds to be too extreme. "either your in gear or out, no in between"
Any follow up ?
Tauran
1986 911 Carrera Targa 3.5L Supercharged
Old 06-13-2008, 09:44 AM
A fellow Pelacanite
NathanUK's Avatar
Stock disc and a KEP pressure plate would be good. They offer different stages.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 06-14-2008, 02:52 AM
Any follow up ?
I spoke to a few people, including Kennedy who were fairly helpful. I don't recall exactly why I didn't go with them, but something bothered me at the time. I don't recall exactly.
I used a Sachs competition pressure plate, and just replaced the stock friction plate.
Pedal pressure is higher than stock, but the clutch doesn't slip. Not at all. I checked.
Got about 8,000 miles on it now, seems to be holding up well.
Old 06-14-2008, 10:22 AM
