johnman001's Avatar
930 Wastegate Question
I just recently (the last time I rove my 930) noticed that my boost is suddenly higher than I have ever seen. The needle now extends well to the right. It seems to have plenty of power, but it concerned me so I tried staying off boost for the remainder of the drive.
I decided that the wastegate must be sticking or some problem with it.
I looked in my manuals and it said to apply pressure to the hose leading to it from the intercooler (control line).
I rigged up a regulator and a gauge and applied pressure to the line.
At .8 bar (12-13psi) the valve seems to remain closed. At 1.1 bar the valve can be heard to open and close, but a hissing sound can be heard as air is escaping somewhere.
The car always used to run about .8 bar until now.
My main questions are:
1.) Is the diaphragm supposed to hold pressure, or do the y leak slightly?
2.) If I buy a replacement diaphragm from Lindsey Racing, where would I get a new gasket for the wastegate body?
3.) Would a leaking diaphragm be a cause for this overboost condition?
4.) I have seen the TiAL wastegates and believe one of them to be a direct replacement for mine, but I would rather attempt rebuilding mine than spending the extra money right now on a wastegate. (I did read that a rebuilt wastegate may be short lived, but I still want to try).
5.) Are there any other sources for a gasket and the diaphragm?
Thanks for your help/advice. I may try giving Imagine Auto a try since they are local to me.
John
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car...........| 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - Unit Body (TBD)
1971 914 (TBD).....................|
Old 07-21-2007, 06:53 PM
Re: 930 Wastegate Question
John
Did you hook the regulator to the control line for the wastegate? There is a vent also.
The diaphram isn't supposed to leak. However the valve guide will leak some and that is ok. A leaky diaphram will cause an overboost cond.
Imagine auto has the diaphram.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 07-22-2007, 04:30 AM
there are 2 tial units available that would fit the 930 let me know if you would be interested in either.. I can beet anybodies price
Ben
Current project 73 914-6 Gt project rusteration 2.4
914-6werkshop.com ,heat exchangers, oil tanks, etc
Old 07-22-2007, 04:42 AM
johnman001's Avatar
Re: Re: 930 Wastegate Question
I put a regulator and a precision gauge in my compressed air line so I could determine the pressure it takes to open the wastegate.
The wastegate does not hold pressure or vacuum. I am thinking that the diaphragm is the leaky culprit.
I will try obtaining a diaphragm.
Are there any other gaskets in the wastegate housing?
Here is the only picture I found of the internals of a wastegate. Are there any missing parts?
John Flesburg
Old 07-22-2007, 06:25 PM
johnman001's Avatar
Sending you an e-mail....
John Flesburg
Old 07-22-2007, 08:44 PM
