Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Typically my 85 hovers around the first dash line, which means if I'm in stop-n-go traffic, it moves a little bit above the first dash, however, yesterday, with the temps in the low 90's in central NJ, it moved up, a little more than half-way between the first dash and the second dash. I started to get concerned as I'd never seen it that high before. Based upon what I'm reading in this thread, that's not too bad. Should I be concerned?
Scott
___________________________
1985 Carrera Targa - Guards Red
2006 Acura TSX Navigation - Milano Red
Old 08-01-2007, 04:21 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Here's the inside of the gauge off my 87. The small line at 12 o'clock is 212*
Old 08-01-2007, 06:13 PM
Thanks, that's about where I was yesterday, while idling in the hot 90 deg. weather.
Scott
Old 08-01-2007, 06:24 PM
Boost Freak
Maxx1's Avatar
On a 90 degree day, in traffic, mine maxes out at 210.
82 Porsche 930 Euro, black, 31K miles.
Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
Old 08-04-2007, 11:56 AM
Here's the inside of the gauge off my 87. The small line at 12 o'clock is 212*[/img]
I would think that mark would be approx 220, as the white mark below it is 194 and the white mark above is 248. I guess gauge is not linear???
If you are correct, and it is actually 212, it sure makes my day!!!!
Tim.
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 08-04-2007, 03:05 PM
A930Rocket's Avatar
The other lines and numbers are in Celcius.
Tim.
Old 08-04-2007, 05:37 PM
Yes, I see the Celsius marks/numbers on my gauge, but the second white mark converts to 194F (90C = 194F) and the third converts to 248F (120C = 248F). And accordimg to your post, the white "hash" is 212F. The white "hash" is what I am curious about, as it is a little over halfway between the 2nd and 3rd white marks, which, if the scale is linear, would put it over 220F.
Where did you get the info on the "hash" mark?
Tim
1986 930
Old 08-04-2007, 08:38 PM
What a relief! Got the new #ed gauge in & installed. Took it out for a 20 mile one way to mother in laws this evening. After it warmed up ran about 210ish. On the way home, it was a little cooler out side, ran about 200 all the way home, then heated up to about 210 on the slow road. Was worried for a minute!
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 08-08-2007, 11:17 PM
Archie930's Avatar
Mine rarely gets above the 90 deg C mark.
Living in tropical Queensland I really try and avoid mid-day temps and heavy traffic in summer.
I found the bumper scoup I got from Pelican does keep the temp down a wee bit when on the move. That little bit of ram air going to the cooler can only help.
Old 08-09-2007, 04:01 AM
one of the great unwashed
patkeefe's Avatar
I tried to simulate track conditions driving home the other day in my turbo SC. I had 93F ambient, 116F entering my airbox, and the oil temp (according to the gauge) was at approximately 130C/266F. I was driving in third gear at between 5000-6000 RPM for about 18 miles.
I think that's a bit too toasty. Looks like I'll have to figure a way to get a third oil cooler, or get my front tube syle Carrera cooler to work better.
Patrick E. Keefe
78 SC
01 Boxster
Old 08-10-2007, 05:09 PM
A930Rocket's Avatar
266F is HOT. The tube type coolers are good heat sinks, but you need to get air to it. I'd think about swapping it for a radiator type oil cooler with air going to it (and a fan).
Old 08-10-2007, 05:26 PM
patkeefe's Avatar
Yeah. I had a smaller Mocal, no fan, figured I'd give the tube type a try. I'm going to switch it back, and do maybe a bumper mod. I have an air scoop where the running light was. I'll report the findings.
BTW, normal driving is about at the halfway (105C) mark.
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 08-10-2007, 06:04 PM
patkeefe's Avatar
I have a sign in my office..."If you can measure it, you can manage it".
I have a three probe digital temperature meter set up today as a test. I have one probe on the supply line to the fron oil cooler, one on the return from the front oil cooler, and one on the line from the auxiliary thermostat to the oil tank. I was getting some funny temp readings yesterday with my infrared gun, and I want to verify proper auxiliary thermostat operation, and maybe try to infer some flow rates (difficult).
So, today, we'll take a little trip to Grandma's house, and my lovely assistant juliekeefe will record these readings for posterity.
I also cut a slot in the front bumper yesterday for (hopefully) improved airflow to the brass cooler. We shall see.
Pat
I put the results here:
http://forums.pelicanparts.com/porsche-911-technical-forum/361666-front-oil-cooler-high-oil-temps.html#post3423094
Patrick E. Keefe
78 SC
01 Boxster
Old 08-12-2007, 05:49 AM
Mark Mcgarry's Avatar
The more air the better........
81 930 euro sunroof delete
Garrett custom turbo, Tec 3 EFI, 964cams, GT3 oil pump
Andial intercooler, Tial wastegate
RarlyL8 headers and muffler
Lindseys 9s 11s
Old 08-13-2007, 06:50 AM
One thing that I have noticed is that no one is mentioned how hot their rear bumper gets with some of these higher temperatures (212! Yikes!).
I hit the mid-way mark after maybe an hour of spirited driving in 80 deg weather, but never creeps beyond that - bumper is roasting. Even a half-hour drive that only brings the needle just above the lower white line (90 deg mark on guage) makes the bumper quite hot. I have the heat shield installed, but not the rear valance (running a M&K Zork that doesn't clear the rear valance).
Am I the only one with this issue?
Suggestions are more than welcome!
Rob
79 930
Old 08-13-2007, 07:57 AM
patkeefe's Avatar
Rob:
In hot weather, my bumper got so hot you could barely touch it, and that was pre-turbo.
Mark-nice valance! Looks great.
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 08-13-2007, 08:03 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
