Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
WUR woes
1991 Turbo ...... I installed a new WUR after the old one suffered a ruptured diaphram; its a modified one by Brian Leask. In checking the initial pressures, I find no voltage to the warm up coils. Anyone have a diagram with current flow for the engine system? Thoughts? Thanks.
Dixon
Old 07-26-2007, 04:23 PM
Wo ist die Rennstrecke?
DonE's Avatar
It is 12v switched. I had to replace the bosch type plug because the contacts failed.
Old 07-26-2007, 05:23 PM
930turbo's Avatar
The voltage must be checked with the rear fuel pump running. Nothing there without it. FYI
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 08-23-2007, 05:32 PM
Dixon ,I have service man. for your car w/factory wiring dia. When i open shop tomorrow i can photo what you need and E- mail it to you if you still need it by then. I'll ck. with you then and see.
Old 08-23-2007, 07:32 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
