iamchappy's Avatar
Is my Tial 38 going to be to small
Will my 38mm Tial be to small with my K27 7200 on my 3.1 engine. Looking to keep the Hp around 400 or less.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 07-30-2007, 04:25 PM
probably just fine. we use 38mm on our kits for low boost 3.2 kits.. I use 46 but I own the company
Ben
Current project 73 914-6 Gt project rusteration 2.4
914-6werkshop.com ,heat exchangers, oil tanks, etc
Old 07-30-2007, 05:47 PM
iamchappy's Avatar
Ben I hope to run 1 bar of boost if thats going to make a difference. If I ever upgrade to the High Flow will I need a 46. I would rather be on the safe side than borderline.
87 924S
Lexus SC400
Lexus LS400
Old 07-30-2007, 07:26 PM
I would run a 46 to be safe then with that much boost.. its always better safe then sorry
Ben
Old 07-31-2007, 05:25 AM
iamchappy's Avatar
Ok I will contact you for a 46
87 924S
Lexus SC400
Lexus LS400
Old 07-31-2007, 07:52 AM
Ken911's Avatar
i have a 46mm waste gate with a 5psi spring. the reason for the low spring is for the eletcronic boost controller, which is not hooked up yet, But with a k-27 hfs turbo it still runs at .9 bar so with a 38 mm you might overboost. still working the bugs out and tuning everything but my stock clutch went south before i had everything dialed in. So hopefully in a couple weeks....
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 07-31-2007, 02:42 PM
iamchappy's Avatar
I use a Turbo X MBC to control boost also, my 38 has a .5 spring also. I have never run boost
past 9lbs with the K27 as my other engine it was hooked up too was a 3.0 SC engine.
Now with the 3.3 pistons and cylinders, lower compression, twin plug and Euro CIS from an 86 with a 7th injector and intercooler. I would like to run up to 1 bar.
I hope I can fit the 46mm in the space I have the 38 or I will have to make up a new crossover pipe.
87 924S
Lexus SC400
Lexus LS400
Old 07-31-2007, 03:27 PM
Ken911's Avatar
the stock waste gate is a 46 dont see why it shouldnt fit
Old 07-31-2007, 04:12 PM
iamchappy's Avatar
Because it goes on this, used in my 914
87 924S
Lexus SC400
Lexus LS400
Old 07-31-2007, 05:55 PM
