930 Tach with boost question
Anyone have expierence wiring up a 930 tach with a turbo conversion? Is there a sensor that needs to be wired into the intake to measure pressure? If so can it be wired directly or is there some voodoo wiring that has to be performed?
I just purchased the tach from a fellow Pelican and would really rather use this gauge instead of clustering up my dash.
Old 08-09-2007, 05:31 AM
I think I anwsered half my uestion and found the part diagram below, still need to know if this will directly wire in?
Old 08-09-2007, 05:36 AM
7.0:1 > 11.3:1
Yes, you can wire directly. It is only one wire coming from the sender, and the sender grounds to chassis through it's body.
My gauge is a 79, this is from another post I wrote:
Sequence on the back of the tach/boost gauge from drivers side to passenger side is brown (ground), Brown with white (boost sender), Black purple (tach input), red (+12 volts)
Old 08-09-2007, 06:55 AM
That is great, I also checked my 930 intake and it appears to have the sender already installed
Old 08-09-2007, 07:08 AM
