Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
930 tranny hold up to ...?
I'm pretty sure I know the answer but just want to know for sure.
Will a 930 lsd tranny last in a 1500# car powered by a 350 ft-lb tq V8 (mid engine) with 315's in which the driver has an affinity for burnouts?
Old 08-09-2007, 11:57 PM
Crotchety Old Bastard
RarlyL8's Avatar
My 915 has stood up to that. A 930 wouldn't even flench. Your clutch is another issue ......
Pictures of the Ultima?
Old 08-10-2007, 07:06 AM
Easy peasy
Old 08-10-2007, 07:29 AM
beepbeep's Avatar
Torque-wise, no problems. A rebuilt 930 tranny that was earmarked for our project car ended up in Ultima with turbocharged bigblock. No problems untill his homemade flywheel desintegrated and flew out trough the side, taking the bellhousing with it.
You should install some sort of oil-cooling though, if you plan to transmit lot's of power trough it a longer time.
Thank you for your time,
Old 08-10-2007, 07:33 AM
930 torque rating
I believe the early 930's were rated at 700 torque.
76 911S
81 911SC
66 912 V8
71 914
65 912
KAW H2 FAST-BY-GAST
Old 08-10-2007, 07:48 AM
lin7310948's Avatar
v8 torque
i have run a short bellhousing 930 tranny in my 2250 pound 911 coupe with sbc 475 crank hp for almost three years with no problems. i run 9 inch fuchs on the rear. currently having built an all aluminum 434 sbc using dart block speced to 600 crank horsepower. engine has forged internals capable of 200-300 hp nos shot. engine will be comparable in weight to the original engine and weigh 105 pounds less than the current engine. you will need a capable clutch and pressure plate. i use kennedy engineered products stage 2 pressure plate and kevlar clutch disc.
71 911 all alum 434 sbc 585 chp 1959 austin healey bn-6 sbc zz4 motor 200r4 aod transmission......1959 Austin healey bn6 250 chev in line six cylinder, tremec 5 speed
Old 08-10-2007, 12:43 PM
Yeah, but what about holding up to burnouts with this setup?
Old 08-14-2007, 04:15 PM
ManaMan's Avatar
Your setup is fine...it's the clutch that is the weak link. I've done some huge smokers at the waterbox....after about the 10th time down the 1/4 mile, the clutch let go. I'm looking for a better clutch now, probably go with the full race puck clutch this time around. You'll smoke the tires before you hurt the 930.
'77 930 euro project
Old 08-16-2007, 12:27 AM
GO DAWG GO's Avatar
You should get some Kenisis wheels, I have some for sale again... The last guy never picked them up!
Hmmmm?
Bob
1 bad 930
Old 08-17-2007, 07:02 AM
Bob-
I've tried calling you several times. Could you give me a call?
Thanks-
Craig
Old 08-18-2007, 12:16 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
