-   -   911sc turbo boost limits (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/363286-911sc-turbo-boost-limits.html)
Kroggers 01-15-2008 06:37 AM
Originally Posted by WydRyd (Post 3704641)
A 3.2 Carrera motor will handle 0.7bar/10psi of boost all day every day, at the stock C/R of 9.5:1 (with intercooler). I can't see why the SC motor won't handle that with the proper adjustments to fuel and ignition delivery.
US or RoW SC?
jbrinkley 01-15-2008 06:40 AM
he said carrera, but US carrera @ 9.5
raceman 01-15-2008 10:53 AM
l run my 3.2 at .8 bar with full bay intercooler and dialed FMU fueling,all the guages to monitor the engine perameters. To say the car is quick is laughable,it plain out RIPS and actually runs cooler now then it did N/A. l`ve seen SC`s running 12PSI with no problems but with the right set-up 10psi should be dead reliable. The right set-up being enough fuel and correct timing with an efficient intercooler system,botch up the basics and as expected you will have a failed engine. The most important thing to buy before you start running the turbo system is a wideband guage/controller, it`s a must have and without it you`re guessing
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
