Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Shifter Rod Seal.....What a Pain!!
Just changed it out. Had a light leak under there. I just dont like leaks. So I figure since I had the time I changed it. Bought some sharp curved picks from Sears, as well as some small needle nose pliers. Changed it via the access hole on the top of the Trans. I just kept digging at it, thought that I had bent something, so I was trying to bend it back, it was the metal under the seal, which is a Metal seal covered by plastic. Anyways it did not want to move until I bent it, then worked the pliers in, after about 1/2 - 1 hour total, it finally came out. New one went in with a metal washer over it & 2 big socket wrenches for pressure tapped by a hammer. Glad it is done & I didnt have to jack up the car & remove the cross member. It was a B#@$* to get that thing out.
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 08-24-2007, 06:51 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
