Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
I just saw this thread, and its good to see that you got everything back in order. For the future, I have a spare stock euro fuel dizzy, with sensor plate etc. if this happens again and you need a temporary solution.
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 08-28-2007, 07:07 PM
Boost Freak
Maxx1's Avatar
Originally Posted by sand_man View Post
Thanks to all for the input, advice, and patience!
The car is back to it's smooth ol' self!
I ended up pulling the fuel head. These things really aren't meant to be disassembled and/or tampered with (unless you're Porschephd)...so I proceeded with care and only cleaned things...know your limits. I think it's possible the workings were just sort of gummed up where the head sits on the metering housing. Also it's possible some shiat came out when I removed the regulator side of the head. Once I re-installed it and pressurized the fuel system, the sensor plate acted with much more sensitivity...the car started right up
As others pointed out, the sensor plate does have some resistance when the fuel is flowing.
MANY THANKS TO ALL!
You are scaring me man .......
...... I hope mine never does that ...... at least you got it fixed and we all benefit from seeing what the problem was and how you fixed it.
82 Porsche 930 Euro, black, 31K miles.
Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
Old 08-30-2007, 04:44 AM
Crotchety Old Bastard
RarlyL8's Avatar
I would not be afraid of the fuel head. It is a close tolerence machined piece that just needs to be kept perfectly clean. If you are meticulous and keep a clean work area it is no problem.
I know there are a couple of threads showing one being rebuilt here on the BBS.
Old 08-30-2007, 05:56 AM
Boost Freak
Maxx1's Avatar
Question
Forgive the dumb question, but is the fuel head the top part of the intake that houses the flapper and has all the semi loose screws with the springs on them ... and the metering plate is underneath, or am I way off track?
I just asked because I always wondered if those screws were supposed to all be loose and if so, how loose?
Old 08-30-2007, 01:43 PM
Man, the PO of your car was about the most limp wristed guy that ever worked on a car! LOL.
Just kidding. I don't know if those screws are supposed to be loose or not.
Old 08-30-2007, 04:00 PM
"I wuz the liquor..."
sand_man's Avatar
Actually in the workshop manual, there is a page about those screws and associated springs. There is a specific method for tightening them. I'll have to dig it out.
-jeff
Old 08-30-2007, 04:15 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
