Thanks for the reply Craig! The same question was asked on Rennlist and I'll paste my response here from my RL thread:
Originally Posted by schnele
Hey Olli is the dyno chart reflecting rear wheel HP or Flywheel, the chart indicates the latter. Great numbers either way and done in great time as well.
I was surprised about that too. I ended up calling Dynapack USA to ask about that. The answer was that provided the total correction factor (tcf on the chart) is one (1), it is the rear-wheel power as "seen" by the Flywheel divided by the ratio shown on the chart, in this case 3.86. (at least that's my best understanding of the confusing explanation). The ratio apparently is the final drive ratio multiplied by the gear ratio of the gear used. For instance with the torque, apparently what the flywheel "sees" as the rear wheel torque using my chart earlier as an example, is a little over 2000 lb-ft, and to translate that to the real number you have to adjust for the ratio.
How's that for a convoluted long answer
The short answer is that it is rear wheel power. Apparently Dynapack removed the word Flywheel in the later versions of the software because it was causing too much confusion."
Olli Selander
1989 930 - 3.5l - M48 - G64/51
Old 09-17-2007, 06:27 PM
I can assure you it is rear wheel HP, my car made 425 on this dyno as well as 435 on a mustang chassis dyno with eddy current for steady stating. The engine was blown in both instances but now I know it is being done right. Stay posted for numbers! Coming Soon!
Old 09-17-2007, 07:10 PM
Me like track days
Craig 930 RS's Avatar
WOW. Congratulations!
Have pictures or further descriptions/build data/links?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 09-18-2007, 07:45 AM
Originally Posted by Craig 930 RS View Post
....Have pictures or further descriptions/build data/links?
Thanks Craig! Here is the link to my thread:
http://forums.rennlist.com/rennforums/showthread.php?t=343048
Lincoln will no doubt post his results shortly. They should be real good since he has a more complete build than mine. I need to do it in pieces due to financial reasons.
Olli Selander
Old 09-18-2007, 09:18 AM
Wo ist die Rennstrecke?
DonE's Avatar
OMG - this is what I love about dyno's - correction factors and convoluted explanations. At least you have a ball-park idea, which is perfectly fine.
Old 09-18-2007, 04:45 PM
