Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Exhaust Noise
Hi All
Have a 1988 turbo 930 with dual out B&B exhaust with headers. My concern
is over the high amount of rumbling and popping sound I get when decelerating, is this normal with the dual out set-up and B&B muffler. At this point in time can't really tell if it is an actual backfire but don't believe so, just allot of popping when the gas pedal is let off????
Thanks to all who reply
Old 09-03-2007, 07:20 AM
Driver
Noah930's Avatar
The characteristic turbo burble? Normal. Did you purchase the car with these already added? Or is this a mod you've just done, yourself?
1987 Venetian Blue (really looks like grey) 930 Coupe
Old 09-03-2007, 07:28 AM
I had a dual-out GHL on my '86 for a while. The popping is likely because the dual outlets let in a lot of air which, combined with a nice healthy rich mixture, ignites in the muffler. This noise was reduced quite a bit when I went with a single-out. The rich mixture is good for a turbo and the popping is normal for a dual-out (or a zork tube for that matter). Enjoy the sounds!
Andy Glass
'86 930 Kokeln IC, K27-7200, SC cams, GHL headers, Fabspeed muffler, Short R&P , misc other mistakes made...
Old 09-03-2007, 07:33 AM
Noah 930
Purchased the car with the the modified exhaust already so never really had a baseline to compare to, thanks for your knowledgeable replies
Old 09-03-2007, 07:53 AM
That's the way they are, if it wouldn't that'll be a concern.
Old 09-03-2007, 10:22 AM
Crotchety Old Bastard
RarlyL8's Avatar
The "cackle" is not necessarily a product of a dual outlet design.
My single outlet muffler cackles quite loudly on decel. The dual outlet prototype that I am running now is actually more quiet and cackles less.
What accents the cackling is a lack of restriction which is a good thing. The more sound deadening material and the more narrow the ID of the system the more quiet (and restrictive) it becomes. Also, a straight through design is more prone to cackle than a baffled design. An empty can, such as the B&B, has potential to be a cackle monster.
You can tune some of that noise out by going more lean on your CO but that defeats the purpose of a performance system. What I do is simply push in the clutch when I don't want to hear it.
Old 09-03-2007, 10:45 AM
Metal Guru
911nut's Avatar
Should have heard the old turbo formula one cars. Sounded like gunshots.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 09-03-2007, 12:17 PM
You might find that you can significantly reduce the amount of popping and banging by not taking your foot completely off the throttle on the overrun - just leave it in 1/8" or so. Worked for me when I had an open pipe.
I think this works because the motor actually burns the fuel then...
'77 S with '78 930 power and a few other things.
Old 09-04-2007, 12:37 PM
RarlyL8's Avatar
I believe the sounds you are describing are more a result of pressure waves caused by the exhaust trying to suck back through a spinning turbin than an ignition event. My muffler cackles when leaving the garage with the engine, turbo, and exhaust bone cold. The sound does become more pronounced as the engine warms.
Old 09-04-2007, 01:36 PM
Ken911's Avatar
makes it kind of hard to let off the throttle to avoid attention when a cop car goes by though. i had one pull in behind me a few day back and instinctivly lett of the gass and looked at the speedometer only to hear a bunch of loud pops and crackles . I was sure I was going to get pulled over but he just kept going.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 09-05-2007, 12:19 PM
Driver
Noah930's Avatar
When do you ever not want to hear it?!
Agree with everything else you've said, as my car does that, too, even when cold.
Old 09-05-2007, 04:34 PM
RarlyL8's Avatar
Ha! Yes there are times. Most recently it was in a hospital zone. I think Ken911 found a time when you don't want it as well!
Old 09-05-2007, 05:07 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
