Finally Got The H4's And HID's Installed (Pics)
After many months of waiting to have the body shop try to match my paint I ordered my own paint and I must say its pretty darn close. I can't believe the difference the H4's make the car look. Anyway here are some pictures I took after I did the install.
Let me know if anyone might be interested in a set of Hid's. I paid $220 for them and they are plug and play. A buddy of mine has a friend that sells them.
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 09-04-2007, 02:52 PM
juicersr's Avatar
Very Nice! Will PM'd you for the name of your friend to get me some of them. Sick of my lame azz H4's
'79 930/934 replica
80 RSR-look(Now in Sicily)
914/6 2.7 (Projekt 908/3)
1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW
D-Zug Produkte/D-Zug.com
Old 09-04-2007, 04:57 PM
Send a message via Yahoo to Lukesportsman
I've always been scared of the "cheap" HID's so I went 100w and relays....kind of wish otherwise now. They look great. How are they rated: Candle power or equivalent halogen bulb (like they rate fluorescent conversion bulbs)?
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v803996TT
Old 09-04-2007, 05:37 PM
They are rated at 35W. I don't know if I would call them cheap. I had a set in my E55, I know an $80K car with no factory Hid's
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 09-04-2007, 06:09 PM
75'930cab's Avatar
I think Lukesportsman meant the cheap HID kits on eBay and what not.
67 Triumph TR4a irs
72 DeTomaso Pantera
75 911 3.3 Turbo Cab*SOLD 5-11-04
73 911T Went Up in a Blaze Glory, 76 Early Ford Bronco
Old 09-04-2007, 08:23 PM
spence88mph's Avatar
would love some plug and play HIDs and will pay $220, where do I get em?
'89 911 M491+Turbo
'89 944 Turbo
'88 928S4
'18 C63S Coupe
Old 09-04-2007, 09:13 PM
Macht Schnell
les_garten's Avatar
Hid
Hi BMAN,
Have you driven the car at night to assess the pattern and functionality of the lights?
My understanding of HID lights is that they need a Focused projector lens to pattern correctly and that has been the problem of some of the cheaper "Kits" out there. They are bright and white, but don't work well as lights.
Can you "Illuminate" on this?
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 09-05-2007, 08:04 AM
Originally Posted by les_garten View Post
Hi BMAN,
Les
No... Not yet. But yes your right without the projector lens it will be all over the road but anything is better then the stock lights for me.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 09-05-2007, 03:38 PM
skipdup's Avatar
Aren't the proper projectors for HID's necessary because of the affect they have on on-coming traffic? IIRC, they are so bright, it becomes a safety issue to those sharing the road with you - IF they're not projected and aimed correctly.
Also, I believe aiming is so important (with this style of lighting) that OEM's must have auto-leveling light assemblies, to keep the lights aimed correctly when the load (passengers, groceries, luggage, etc) changes.
Not positive about any of this. Just seems like what I remember.
- Skip
1971 911T w/2.4
Old 09-05-2007, 03:51 PM
Gumba11's Avatar
I have a Hella HID kit in my 930 and I have had one person flash me in about three years of having them. The light output even with yellow lenses is sooo much better !
Just my .02...........................C
77 930 "P Zilla" 3.2 Litre w / EFI conversion
Old 09-05-2007, 03:57 PM
I'm thinking about doing this to my 930 and my cab, but I have a couple questions.
- How do you fit the ballast and ignitor in the bucket?
- IIRC, the stock light have one bulb for low/high. Do you still have high beams?
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 01-29-2008, 02:24 AM
Cowtown10's Avatar
I have been looking at doing the conversion as well. I have found this site...anyone buy from them?
http://www.hellahid.com/products.php
Q
2002 996TT
1984 930 Turbo (gone and missed)
Old 01-29-2008, 09:26 AM
Crotchety Old Bastard
RarlyL8's Avatar
I'm in if they work as described. Those H4s are horrible, I have driving lights mounted that I would love to get rid of.
Old 01-29-2008, 10:47 AM
Me like track days
Craig 930 RS's Avatar
H4 lens aims perfectly. A nice setup if you drive at night, congratulations.
I have H1s, love 'em -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-29-2008, 11:28 AM
Macht Schnell
les_garten's Avatar
Craig, are you using the lights from the link above?
les
Old 01-29-2008, 12:23 PM
Me like track days
No, I think what I said was misleading - I have stock H1s - the light pattern is great on both the H4 and H1s, so it lends itself to a non-offensive chage to a HID setup within either lens -
Old 01-29-2008, 12:54 PM
They fit not pretty but they do fit. What I did was wire everything up, put the light in on the top clip and jam everything in and close the light up. I do have have beams but trust me you wont need them.
I just installed a set on my 90 Jetta VR6 turbo swap and it was night and day difference
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 01-29-2008, 03:36 PM
81turboporsche's Avatar
Send a message via AIM to 81turboporsche
can u throw up a pic of them turned on,ive been thinking of throwing a set on my car,i did the h4 headlight upgrade and its a little bit brighter then the oem lights for 81 but h.i.d.s make everything better
Old 01-29-2008, 05:26 PM
Macht Schnell
les_garten's Avatar
So which kit did you install here?
Les
Old 01-29-2008, 05:59 PM
Les
Same as the Porsche. I got them from a local that sells them. Nothing special about his kits.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 01-29-2008, 07:11 PM
