930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
i dont see a listing for these bushings anywhere. im starting to think they dont exist
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-11-2007, 04:21 PM
Porschephd's Avatar
Look under tranny on Pelican and it is under shifter coupler bushings.
Stephen
94 3.6Turbo 6-speed AWD
Old 09-11-2007, 07:34 PM
Crotchety Old Bastard
RarlyL8's Avatar
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_Tshift_pg1.htm#item3
Old 09-12-2007, 05:18 AM
A fellow Pelacanite
NathanUK's Avatar
http://www.pelicanparts.com/cgi-bin/PartsLookup/search.cgi?command=show_page&Catalog_Name=911_USA_78_83_KATALOG&Illustration=301-05&Line_Item=2
Doesn't look like there is any bushings for that shaft.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 09-12-2007, 07:09 AM
notthd's Avatar
Another Jack option. I use a truck transmission jack. It adjusts its cradle, It is very helpful in that it not only goes up and down but has tilt front to back and side to side adjustments. With the adjustments I was able to remove the combo with the rear bumper still on. Found it at NAPA
Four jack stands- 2 primary 2 for safety
Old 09-17-2007, 05:39 AM
hey isnt that just garage door angle bracket ... you know the mounting hardware for the garage door motor and the roller channel supports......
1987 930 -Guards Red
2001 740I sport Blk
2011 F-150 supercrew Blk
2014 X3 2.8 white
"What goes around comes around..."
Old 09-17-2007, 09:44 AM
loot87's Avatar
Sandman,
When you jack it back up, what jack points do you use?
Chris Cope
91 911 Turbo
Lyons, Colorado
Old 09-17-2007, 10:08 AM
