930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
New clutch do I have to drop trans?
Do I have to drop the trans with clutch replacement or can I just drop the motor? I also plan on,fixing oil leaks, pulling air injection and a/c and upgrading to carrera tensioners. Any feedback would be awesome.
Thanks Pete
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-07-2007, 05:19 PM
Send a message via Yahoo to Lukesportsman
I'd pull the whole thing. Sure it means a few more bolts, but the axles are really just dumb labor. Sure, you can fight around it and "might" save some time or perceived effort. BUT if you've ever had a new clutch pack that didn't want to line up with the trans input shaft, you'd regret it. I much rather hold a transmission between my legs and wiggle than an engine above my head.
You asked for opinions
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 09-07-2007, 06:01 PM
h20cooled7's Avatar
No ,and I appreciate your opinion ! Do you remove the axles or just let them hang?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-07-2007, 06:23 PM
Porschephd's Avatar
Just let them hang. I use to pull the motor only when I was a 20 but as I got older I found just dropping the whole thing is really faster. You spend more time trying to get the cars rear high enough in the air, then splining up the tranny etc. It is must faster to pull the whole thing.
Stephen
94 3.6Turbo 6-speed AWD
Old 09-07-2007, 08:57 PM
h20cooled7's Avatar
ok if i remove the valance under the bumper how high do i have to get the car and do i remove the rear bumper or leave it on? also do you just use jack stands on the rear or can i get more clearance with them on the front also?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-08-2007, 06:21 AM
Porschephd's Avatar
You are better off leaving the nose down and pulling the rear bumper all together.
Stephen
Old 09-08-2007, 07:43 AM
resident samsquamch
sand_man's Avatar
I've had my engine/tranny out a number of times. Here are a few tips:
-Once you've gotten everything disconnected from the engine/tranny assembly, lower the car back down to the ground.
-Remove the entire rear bumper (valence and all)...it's easy to do, and will save you several inches of height.
-I bought and modified a furniture dolly. Instead of looking like a square it now looks like a "U".
-After I have centered the dolly under the engine (placed as such so that the engine and tranny will be properly balanced when they come out).
-I place my floor jack inside the "U".
-There is a point on the engine case, just behind of the engine/tanny bell housing, this is a good balance spot to place your jack on.
-keep in mind the car should still be on the ground.
-Firmly support the engine/tranny with the jack...put some padding in between the jack and the engine case.
-Unbolt the tranny mounts.
-Unbolt the engine mounts.
-Slowly lower down to the dolly...you won't have far to go because you didn't jack the car sky high. Make sure you do this slowly so that you can be sure you've disconnected everything.
-Once the engine/tranny is on the dolly, remove the jack...that's why you need the "U" in the dolly...so you can get the jack out.
-Then jack up the car, and roll the engine/tranny out from under it.
-Once it's clear, lower the car back down tot the ground.
All of the above assumes that you are using a quality jack and quality jack stands. NEVER work under a car supported just by a jack!! NEVER!
-jeff
Old 09-08-2007, 07:47 AM
Welcome back Stephen....we don't see much of you over here
+1 on his comments
Luke S.
I may have to try Sandman's idea over the motorcyle lift I've always used...sounds like a slick drama free one man method... cool and inexpensive.
Luke S.
Old 09-08-2007, 07:50 AM
resident samsquamch
sand_man's Avatar
I like to leave the car on the ground, because it gets scary having it jacked so high (even supported by jack stands) as you're working with such a heavy engine/tranny unit. Also if something goes wrong and god forbid the engine falls, it doesn't have far to go.
-jeff
Old 09-08-2007, 07:56 AM
h20cooled7's Avatar
waiting on a set of brand new 6 ton jack stands from Mac, I didnt trust those cheesey china made ones ,too unstable. let me run this by you . i have the factory turbo manuals. they show bushings for the lever shaft that the release fork goes on but i cant find these bushings in any parts fische. are these bushings available and do they go bad?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-08-2007, 07:59 AM
Porschephd's Avatar
There is a guy that use to make a engine mount for a normal jack on Ebay. I use to use one of these. It was a cradle and worked well. Keep in mind this was 15 years ago when I worked out of the garage. You can buy 'good" jackstands for trucks which give you the height and support you need. It will cost more than the units you get from Pep Boys for 13.00 but this is a safety measure. If you can score one of the cradles then you will be golden. You could also use a low boy tranny jack. It would do the same thing.
Thanks Luke. Good to see ya here too.
Stephen
Old 09-08-2007, 08:19 AM
resident samsquamch
sand_man's Avatar
I like to support my CVs with coat hangers...like this:
-jeff
Old 09-08-2007, 09:43 AM
h20cooled7's Avatar
what about the bushings ?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-08-2007, 11:52 AM
h20cooled7's Avatar
any one on rebushing the lever shaft?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-10-2007, 06:48 PM
Porschephd's Avatar
On the coupler? Hell yes while it is out put some bushing in there.
Stephen
Old 09-10-2007, 07:03 PM
A fellow Pelacanite
NathanUK's Avatar
Pelican does a metal bracket that fits onto the engine sump for a trolley jack. I am going to get one next time I have to do a removal.
http://www.pelicanparts.com/catalog/shopcart/PORS/POR_PORS_PTOOLS_pg1.htm
h20, check out a PET.
http://www.porsche.com/uk/accessoriesandservice/classic/genuineparts/originalpartscatalogue/originalpartspdfcatalogue/
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 09-11-2007, 12:18 PM
Macht Schnell
les_garten's Avatar
Nice coil pack mounting. Did you buy that angle Aluminum someplace? I have mine in the same position, but they don't look that good!
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 09-11-2007, 03:06 PM
resident samsquamch
sand_man's Avatar
Les
If I said Ace Hardware...would I be shunned from this community FOREVER? In that case I didn't buy the angle iron from Ace Hardware, I bought it from NASA! I also bought the rattle can of high temp spray paint from NASA too (in black)!
-jeff
Old 09-11-2007, 04:00 PM
Macht Schnell
les_garten's Avatar
Dude,
Your secret is safe with me, I won't tell anyone. Did you drill the holes yourself?
les
Old 09-11-2007, 04:44 PM
