How did you remove your header nuts?
This winter I'm planning on replacing my stock headers with GHL headers that I bought. I was looking under there the other day and the PS looked easy enough to get to, but the DS looks harder.
I picked up those nut splitters but I don't think they'll fit on the DS. How did you get yours off and did you break any studs? Any tips, tricks or suggestions? |
Lots and lots of PB Blaster. If you can find it, Kroil works wonders:
http://www.kanolabs.com/ I made it a habbit of carefully spraying the nuts/studs constantly over a three day period. When I get home tonight, I'll snap a picture of a tool that I used to access the nuts for removal. |
One guy used a die grinder and cut the nuts in half. He figured replacing the nuts was cheaper/easier than broken studs.
This is just FYI, but when I had my engine a part for the rebuild, I installed the Performance Developments stainless exhuast studs...they are damn nice!
http://performancedevelopments.com/products_engine_studs.php http://img407.imageshack.us/img407/9...ststudscj0.jpg http://img155.imageshack.us/img155/1558/heads5zx.jpg http://img155.imageshack.us/img155/1...ststuds4hv.jpg |
Thanks guys. I'll try to get some of that kroil. I don't mind cutting or splitting the nuts cause I'm planning on replacing all the nuts anyways. I just don't see how you could get a grinder in there esp on the DS.
edit: sand-man, those look very nice! I'd also like to see the tool you used. Did you buy it somewhere or did you make it? |
Bill,
I just ordered a new set of headers from Stephan Kaspar and he said to use the aerokroil.. No equal in the world...simply amazing stuff. I ordered it for 13 bucks and has to be shipped UPS ground because of Haz Mat conditions. Meaning I will have my headers before the penetrating oil...Oh well. Bob |
That stuff really is unreal. Makes PB look like water!
I got my nuts off with vaseline.........sorry had to do it, your wording of the question was too hard to resist.
Just kidding....... |
I ordered up a couple cans of that Kroil. |
I had such a big smile when they started to turn rather easily. Thanks again to the guys at IA! |
You are welcome. Karl actually turned me on to the Kroil.
Thinking back, I never had to remove the stock exhaust system, since my car came with a new set of B&B headers (well almost three years ago, they were new). However, the Porsche shop that installed them for the previous owner must have figured out a way to use an impact wrench on the nuts!!! I was amazed that the shop hadn't broken the studs *INSTALLING* the nuts...hella tight! :D
At any rate this is the collection of wrenches that I used to remove them; once for an engine rebuild, and a second time to replace the B&Bs with OBX. Once things had been soaked for a few days with the Kroil, the nuts came off with ease. Tricky part was figuring out how to access them...hence the offset and shorty combo wrenches pictured. Also, the ratcheting box wrench fitted with that socket was invaluable...I was also able to use that socket with an array of other wrenches. Because the studs/nuts are located diagonal from each other, you can reach them...just takes patience and getting creative with how you fit your wrenches... http://img402.imageshack.us/img402/92/picture033dj6.jpg http://img169.imageshack.us/img169/5...ture046tg2.jpg http://img402.imageshack.us/img402/1...ture036jw1.jpg |
Finally, I'm on a computer that displays your pics. Thanks for sharing. So you didn't really use any too special of tools. I have a nut on one stud and a barrel allen nut on the other stud for each port. I hope that kroil stuff is as good as you guys say cause those barrel nuts make me nervous.
Oh man...I was afraid you'd say "barrel nuts"! Mine had regular nuts all the way around! Is it me or is it weird talking about nuts like this?!?!?!?
Maybe I'll let those (barrel) nuts soak with lots of juicy lubricants (Kroil) for six days. And yes, talking about nuts like this is kinda weird! :eek:
Don't forget to tap them with a hammer!
FYI: I seem to remember seeing some access holes in the bottom of the factory heat exhangers when I was storing my factory exhaust parts. By access, I mean a hole that you could insert an allen or extension to reach the the exhust port above. Sorry if I'm pointing out the obvious. As I mentioned previously, I didn't have to work with the original exhaust....it had already been removed. I dunno, maybe I dreamed it.
Most aftermarket exhausts with heat don't have those access holes - with the exception of maybe the SSI gear. That's why I had to use such a strange collection of wrenches to work around the heater boxes for access. |
Those barrel nuts are easy with a nut splitter. You can then be 100% certain that you will not snap the stud.
I can see the nut splitter working on maybe 3 of them but not all 6. Does the nut splitter fit in there on the DS? Especially #3 cyl (DS Front)? I don't see how you could get a wrench in there let alone a splitter. I haven't done it so initially I'm a non-believer.
Did you get the nut splitter on all 6 barrel nuts? What nut splitter do you have? I have the one from Northern Tool. |
Sandman,
Let me help you.. The little blue pill is for your tool and nuts..The red will help your sinuses..:D I'm taking my nuts off at the moment too. I have them soaking in aerokroil The right hand set came of easily but the left are going to give me a fight. I'm going to tap them in a few minutes and try to break them loose. BTW the 1/4 and 1/2 adapter/ Socket to box end wrench is vital..I bought mine at Sears yesterday to $9.99. Harbor freight has the long allens in metric that are made in Taiwan for $14.99 for the barrel nuts. Its a must too. Reinstallation: I'm wondering if I should use new 8mm class 8 nuts and Stainless washers. What about lockwashers? I know poor quality will crack and fall out in time but what about class 8? Bob |
My best luck with the head studs was a $h!tload of PB blaster and the use of a 1/4 inch impact wrench. The 1/4 impact is useful because it has too little torque to snap the studs and has high frequency, ideal for getting the nuts off with no studs in them. It is absolutely the best feeling when the gun fires off the last nut without it snappinghttp://forums.pelicanparts.com/support/smileys/ar15.gif
12 each of part number 11-62-1-711-954-M58 Copper Lock Nut, 8mm 6 each of part number 930-111-191-12-M17 Metal Exhaust Port Gasket, 911 1984-89 |
I recently used similair tactics on some oil lines on my 3.2 carrera, I sawed into the nuts with a dremel using a disc. It made a tremendous difference in getting them undone. http://farm2.static.flickr.com/1093/...dde1a2afb5.jpg I fitted my new headers with A2 stainless steel nuts and washers, my thinking was that if I needed to get them off again I will just split them so the more brittle the better :) Hope my theory is right... |
GOOD GOD...whose ass did that turd come out of :eek:
LOL, they are a little brown aren't they :o
We have these dumbasses that put salt on the roads in the winter :( |
Seriously, I was wondering about what to put on too. Thanks for the tip! robert_snyder - How's it going? Did you get them off? Like I said, I'm not going to be doing this till this winter. I figured that my car will we off the road for the winter anyways so I can take my time. Besides that, I have a K27 that's going on at the same time. |
| All times are GMT -8. The time now is 07:49 AM. |
