-   -   Fabricating a C2 Turbo to intercooler pipe (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/366674-fabricating-c2-turbo-intercooler-pipe.html)
sand_man 12-20-2007 05:54 AM
User slow&rusty would be a good person to consult on this matter. He does these types of calculations and testing for a living...not to mention all his practical experience with import cars. Back when he had his intercooler fabbed up, I remember him maintaning a boost pipe very similar to the stock 930 one with the taper.
les_garten 12-20-2007 06:11 AM
Sand_Man,
I invited him to comment. I'd like to know how he fabb'd the taper.
Les
sand_man 12-20-2007 06:18 AM
Originally Posted by les_garten (Post 3656938)
Sand_Man,
Les
I might have a picture, but he actually rolled a piece of sheet metal into a cone and had it welded...I think.
RarlyL8 12-20-2007 06:25 AM
The compromise of intercooling is pressure drop. The design of the up-pipe is conular (is that a word?) in order to retain the high pressure exiting the turbo and then transition to the intercooler with a minimum of turbulence.
sand_man 12-20-2007 07:04 AM
info on slownrusty's setup:
http://forums.rennlist.com/rennforums/showthread.php?t=230618
http://pic5.picturetrail.com/VOL86/5.../113771639.jpg
http://pic5.picturetrail.com/VOL86/5.../113771645.jpg
les_garten 12-20-2007 07:28 AM
Yeah, that's what I'm talkin about!
If I see someone walkin' around town with one of these in his back pocket, I'm gonna knock him in the head and take off with it!
Les
les_garten 12-20-2007 07:31 AM
RarlyL8,
Could you Fab up one of these Pipes in the Pictures here. Beats the hell out of the AL adapter POS for the K27. I've got one and want rid of it. I'm willing to bet there's a market for these in SS on this forum.
Les
MyTurbo3.6 12-20-2007 02:10 PM
Burns Stainless has transitions that may work for you...
http://www.burnsstainless.com/Transitions/transitions.html
les_garten 12-20-2007 02:59 PM
Hi,
Thanx, I had bought some pipe from them a number of years ago. I didn't know they did these taper pipes. I'll look into this.
Les
Craig 930 RS 12-20-2007 03:20 PM
After dinkin' with the $300 factory - it is an impressive and robust setup.
Personally I would think of using this and be done with it.
slow&rusty 12-21-2007 08:46 PM
SandMan - Would do you think you are doing posting pics of my crap parts! I'm still trying to figure if a 930Cab is a better investment than a 993 C2!
Ummmm.....welllll seeing that I had an invite to post on this tread by Mr.Garten, I did actually make that pipe from rolling a piece of flat stock aluminum, cutting it and then tack welding it and then taking it to my good friend's MachineShop to be Tig Welded. I took me actually one try and about an hour or so to make
I am going to make a new piece this spring that is longer by about 1.5" on each end and out of slightly thicker wall aluminum.
I did not do any flow calcs on this pipe as obviously there are are now real elbows or flow restrictions in it length. I guess I could have calculated the losses in flow from friction for fun, but it would be minimal (i.e = none)...15psi into it = 15psi out of it.
My home designed intercooler was where I did ALL my homework \ and testing and my aim was to beat the mighty Kokeln, which I did on every aspect (price, flow, losses, power support, retain factory AC) etc etc.
Regards - Yasin
P.S: Nice work on fitment of that C2 IC Sandy! VERY nice!
les_garten 12-21-2007 09:05 PM
Regards - Yasin
Hi Yasin,
The taper is necessary as compared to a straight pipe with silicone transition? I'm thinkin' straight pipe has resistance losses.
Les
slow&rusty 12-22-2007 05:31 AM
All pipes have resistance losses regardless straight or tapered.
In our application...we are splitting hairs here, if you use a staight pipe and a silicone transition is will be as effective as the my pipe or the factory piece. You will NOT see any difference. The pressure we run say between 10-20psi is really small. When you get into higher pressures and long runs of pipe (think in the hundreds of feet) that when you need to think about measuring resistance losses etc.
Focus on the intercooler (espeically if you have a stock one)...then I will talk "losses" with you all day...
Regards - Yasin
Falk930 12-22-2007 06:15 AM
From first view, a tapered ( if I understand correct that this means slightly getting bigger) seems to be a good solution.
More I guess the connections influence flow there.
I would try to meet turbo and IC holes as perfect as possible.
A bad example of connection tube I found on my car.
It was upgraded to K27 11/11 turbo.
They used a silicone hose for the IC connection.
For any reason the hose was bended a little
and made a big bubble to the inside.
For sure this funny thing reduced flow a lot.
Falk
les_garten 12-22-2007 07:43 AM
Regards - Yasin
Hi,
So my next question is 2" straight pipe Turbo to IC, or 3" Straight pipe Turbo to IC?
I'm thinking pressure drop and flow dynamics here.
Les
Craig 930 RS 12-22-2007 07:52 AM
A taper from the turbo to the intercooler will reduce the velocity a bit and will provide a nice transition from the relatively narrow turbo outlet to the realatively large intercooler opening(s) on the entrance tank.
But in reality, I suspect it won't functionally make a hell of a lot of difference as we aren't dealing with refined flow characteristics inside a jet engine --
NathanUK 12-23-2007 11:10 AM
Just incase you guys didn't get the joke :)
http://forums.rennlist.com/rennforums/showthread.php?t=397669
sand_man 12-23-2007 03:36 PM
LOL!!! I've been meaning to post on the 'list again, but I'm just not feelin' it anymore. I'll return one of these days...
spuggy 12-23-2007 04:32 PM
Hhahahahahah! Thanks for that.
Now I remember why I never paid Rennlist any money, and in fact rarely bother to read it anymore.
Most of the more knowledgable RL members are on PP anyway, it doesn't seem to be anywhere as good as PP as either a community or a technical resource, and there's no "ignore" button for trolls or other undesirables.
RarlyL8 12-23-2007 07:10 PM
Have you noticed the number of Rennlisters now on this forum?
Rennlist absolutely sux. Too many egos for my blood.
Les, I probably could fab one up but I'm way too busy to take on anything else. I do have a stock up-pipe that has had the bottom cut off and a silicone hose added (for use with a K27) if anybody needs/wants something like that.
