Turbo Drive Shaft Bolts
I have had a problem with drive shaft Bolts backing out at the transmission flange. The parts diagram for the 930 does not show a lock washer in use. The 911 uses lock washers. Anyone know if I should use the lock washers or a loctite product? I have been torqueing them as much as possible using a regular hex key socket with a standard handle.
Old 09-12-2007, 02:33 PM
BoxxerSix's Avatar
Blue loctite will suit just fine for those. Just be sure the threaded holes in the drive flanges are dry(no oil/grease/debris) for the thread locker to properly bite. Brakleen works great for that
Adam Hennessy
Old 09-12-2007, 02:57 PM
A fellow Pelacanite
NathanUK's Avatar
You could use Schnorr washers, they are great IMO.
http://www.schnorr.com/safetywashers.html
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 09-13-2007, 02:00 AM
Forced Induction Junkie
WERK I's Avatar
Highly recommend you torque them to the factory spec. I have never had a problem of them loosening when torqued to spec and tightening bolts using a star tightening sequence. Also, inspect the threads of all the bolts, if damaged replace.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 09-13-2007, 07:30 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
+1.
You can't do it by hand. You really need that torque wrench and go to 60 ft lbs I think it is. I've never used the schnor (sp?) wahers or loctite and have not had a problem with lots of track use.
Old 09-13-2007, 06:38 PM
beepbeep's Avatar
Use Nordlock washers and clean the threads with brake cleaner prior to installation.
Thank you for your time,
Old 09-14-2007, 06:26 AM
Porschephd's Avatar
Clean the threads as suggested and use a TQ wrench!. I have never had to use loctite nor washers and never had one back out. Now I will tell you that on cars we build for purpose such as track only we actually drill the heads and safety wire them.
Stephen
94 3.6Turbo 6-speed AWD
Old 09-14-2007, 06:31 AM
Thank you all for the suggestions.
Thanks everyone for the advice. I realize I probably did not have them torqued enough after my engine install. It was my first time pulling and installing on my own. If they start to loosen again I will go with the lockwashers or loctite.
Old 09-14-2007, 02:27 PM
A fellow Pelacanite
NathanUK's Avatar
I should have added also that I have never had any come loose & I don't use any loctite, washers or wire. Just the correct Tq.
Old 09-14-2007, 04:28 PM
