Crotchety Old Bastard
RarlyL8's Avatar
Check Out My Latest Project
I'm finishing this up for a customer this weekend.
SSI heat exchangers with custom Y- pipe, waste gate dump tube and polished dual outlet muffler. Sweeet!
Old 09-22-2007, 07:57 PM
DSPTurtle's Avatar
Wow... is there any baffling in the can or is it just there for inspection purposes?
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 09-23-2007, 06:41 AM
RarlyL8's Avatar
Yes, the muffler has a perforated core straight through design.
Old 09-23-2007, 07:02 AM
Adrenaline Junkie
Hayabusa's Avatar
Is this John's final and current 930 heat exchanger set up he has been working on?
Old 09-23-2007, 08:50 PM
RarlyL8's Avatar
Yes.
Same great manufacturing quality bumped up to 347 stainless for the turbo application. The cross over pipe pictured was made with 321 stainless.
Old 09-24-2007, 05:02 AM
Me like track days
Craig 930 RS's Avatar
Have a right side shot?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 09-24-2007, 11:24 AM
RarlyL8's Avatar
Here is a picture of the SSIs installed. Is there something in particular you wanted to see?
Old 09-24-2007, 06:24 PM
Wer bremst verliert
JohnJL's Avatar
schwing
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-25-2007, 03:08 AM
Me like track days
Right side shot of that stainless setup above.
Old 09-25-2007, 06:07 AM
RarlyL8's Avatar
That is the only picture I have of the completed fabbed product. The Y-pipe should return from final welding in a week or so, I can take specific shots then if you like.
For now the installed pic is a good reference, the passenger's side pipe follows the same path as the pipe on the installed picture. They look the same.
Old 09-25-2007, 08:46 AM
looks allot like my 1st iteration
Ben
Current project 73 914-6 Gt project rusteration 2.4
914-6werkshop.com ,heat exchangers, oil tanks, etc
Old 09-25-2007, 08:54 AM
I searched, but didn't see it listed anywhere, what size are the primaries on your SSI headers?
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 10-07-2007, 09:58 AM
Me like track days
Brian -
THIS is a great picture:
Old 10-08-2007, 06:29 PM
RarlyL8's Avatar
Didn't they turn out nice? I am very pleased with that polishing company.
Those items have all been sold to the fellow we are doing the SSI setup for. He has them now and is awaiting the completion of his engine build so they can be mounted. A muffler for the neighbors and a zork for the weekends and car shows. Pretty neat package.
Old 10-09-2007, 07:25 AM
sudo apt-get purge 930
equality72521's Avatar
Isn't it hard on the O2 sensor being that close to the turbo?
--clutch-monkey
Old 10-09-2007, 08:06 AM
Me like track days
IM(NSH)O, an O2 in that location should only be used for brief AFR testing - you WILL kill the O2 in short order if it is left on. I guarantee it.
Just disconnect and plug.
Old 10-09-2007, 08:31 AM
RarlyL8's Avatar
Yes it is hard on the sensor in that position. Unfortunately it is also about the best place to get a good idle A/F reading.
I actually have 3 bungs in different places and plan to do some comparo testing with my LM1. The stock exit muffler is the only one that might get a good idle reading from the bung located on the 180* bend after the muffler. The other mufflers have a tail pipe that is too short to give a good idle A/F reading after the muffler.
Old 10-09-2007, 04:23 PM
