Wer bremst verliert
Turbo setup alternative to supercharger plans
I have a pretty good idea from two local projects, conversations with a few shops that have done supercharger projects and a lot from this site so I think I know what I am getting into with a supercharging project I have been planning for a long time. I'd be interested if someone wants to suggest what a turbocharging alternative would entail given the same price, parts availability and degree of difficulty.
I have a 83SC track car weighing 1040kgs and a naturally aspirated 3.0 I built, giving 240hp. I'm really happy with the engine and am planning on fitting it to my street car. This post is asking about recommendations for the replacement engine for the track car. I am already in "open" class so its 'anything goes.' I can carve up even the quick V8s in the curves, however they pass me back on the main straight. Thank god there's only one of those at EC. I would really like to keep the speed up through the corners (keep weight low and low) but pick up some speed through the straights. With the supercharging project I was keen to keep a linear curve and simplicity. I was also aiming for 400 crank HP, intercooled. Here's what I have already so available as a base for the turbo also: 98MM JE Piston 8:1 ceramic coated, lube skirted new perfect bore cylinders 3.0 case 3.0 crank 3.0 rods (3.2 effective capacity) 3.0 heads (dished to match the cylinders) ARP bolts Either of sc cams or DR 20 (John Dougherty) Adaptronic or Megasquirt ECU (have both) 50lb/hr inhjectors 1984 Carrera aluminum (aluminium) intake Ford EDIS/Haltech twin-plug ignition controlled by ECU 1 5/8" Bursch headers Intercooler was undecided but prefer air-to-air. Supercharger was to be Autorotor 3215 I would appreciate any opinions on what it would take to achieve a similar or better outcome given what I have to work with already. I was budgeting $5,000 additional for the supercharger, intercooler, muffler, and plumbing. I can do everything except TIG welding and tube bending at my home shop. I guess I'm asking for specific thoughts and recommendations for turbo (s?), exhaust, wastegate(s?), plumbing, muffler for the same budget, degree of construction complexity, target figures and longevity. thanks!
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Wer bremst verliert
OK, 50 views and no responses. Let me try being more specific...
Given the list above is the following going to achieve my goals of track-reliable results at a budget under $5,000? K27-HPS or 7002 Burch 1 5/8 headers 50 lbs injectors Tial wastegate 0.9 bar Appropriate oil plumbing Air-air intercooler (suggestions?) I know asking for Intercooler and turbo suggestions are like asking religious questions but would still appreciate dialog. thanks
Did you consider going Garrett instead of KKK regarding the turbocharger?
Thank you for your time, |
Crotchety Old Bastard
Contact Mark Hargett (Natchamp). He has done both supercharging and twin turbos on his 3.0L engine and will be able to give you some good advice.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
A fellow Pelacanite
I am thinking there will be too much throttle lag with a turbo and you would prefer a supercharger.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
status?
I just saw you were online (when writing). I am just curious what is the status of this project.
Regards Jesper |
Wer bremst verliert
I got sidetracked finishing up transplanting engines.
I spent a day with one of hte local project cars and he shared all his technical drawings and build book. Some unbelievable notes and engineering drawings. I've now assembled almost everything I need bar the actual head unit and intercooler. I'll resume after Targa Tassie in April.
Thread Tools | |
Rate This Thread | |
