lin7310948's Avatar
930 clutch release fork?
i need some sage advice as to the throw bearing actuator arm on an early 930 transaxle. i know some of you guys must run some rather extreme clutch and pressure plate combinations. is the stock actuator arm capable of pressure plate spring pressure say...of 600 horsepower...600 ft/lbs of torque? i have broken a couple of 915 arms using stock clutch components. thanks
71 911 all alum 434 sbc 585 chp 1959 austin healey bn-6 sbc zz4 motor 200r4 aod transmission......1959 Austin healey bn6 250 chev in line six cylinder, tremec 5 speed
Old 09-25-2007, 10:33 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I think the stock fork is pretty stout. If you sticking with a cable to operate it, you may need to adjust it or be ready to replace it as there is more strain on it. I just installed a KEP stage 2 clutch in my car with 400 rwhp and so far so good. I did buy the cable as a spare in case I have a problem down the road. The other choice is to with a hydraulic set up like Brian Smith.
Old 09-25-2007, 05:37 PM
lin7310948's Avatar
bump
have any of you big horsepower guys had one of these arms break or fail in some other fashion? i have the trans and motor out and would be a good time to do whatever? thanks
Old 09-26-2007, 03:58 AM
