Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
930 Headers
I have been thinking about doing some upgrades to my 87 930. Read a bunch of posts on this forum and I am still a bit confused about headers. Seems like there are the expensive ones like GHL and B&B and some relatively cheap ones like OBX and GSF. I also know of Schnell but have not seen them mentioned much here. I do not mind paying the price if it is worth it but also do not want to pay more if I do not have to. Is there any consensus on which way to go? By the way I probably will not be using heater boxes on the headers. Thanks
Old 09-26-2007, 06:14 PM
I hear alot of talk on the SSI's. Give Rarelyl8 a shout. I personally bought mine with B&B's already on it. I may have a leak!
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 09-26-2007, 07:04 PM
sudo apt-get purge 930
equality72521's Avatar
I don't know from personal experience but from what I've read the GSF headers are the best bang for the buck.
--clutch-monkey
Crotchety Old Bastard
RarlyL8's Avatar
I do not know who makes the best (no heat) headers right now, there seems to be a lot of turmoil in the industry due to materials costs and Chinese manufacturers. I'd love to sell you a set of SSIs but you can probably save $500 by purchasing headers without heat.
Old 09-26-2007, 08:15 PM
Bully's Avatar
Brian, I live on the west coast of Canada. The idea of headers without heat does not work for me.
I drive a Euro issue car without cats, and I have also removed all of the air pump gear from the exhaust. In your opinion, would I gain all that much going to an aftermarket system? Also can I buy an SSI system WITH heat exchangers?
Many thx
DB
'85 Euro
Old 09-27-2007, 06:22 AM
Greyhound - 930's Avatar
I put a set of non-heat schnell headers on mine about 18 months ago. The welding work was ordinary at best and my mechanic did have to 'work' with them to prevent a leak at a mounting flange as they weren't quite true when a straight bar was laid across the top the mounting faces. No cracks or leaks since installing though, I think I paid about $900.00 for them. I do miss the heat in winter. Good Luck.
Old 09-27-2007, 06:43 AM
RarlyL8's Avatar
SSIs come with the best heat exchangers in the industry.
The increases seen by headers are dependant upon the mods of your engine. If your engine is a bone stock Euro you will see about a 5% HP increase or so but more importantly the torque off boost will be improved which in turn improves driveability. The HP improvements will be more dramatic when combined with other engine modifications.
The best bang for the buck on a stock Euro (in my opinion) would be a non restrictive muffler followed by an upgraded turbo.
Your stock Euro exchangers have enough flow to allow bolt-ons such as turbos and higher boost springs to enhance your engine. I run them on my car to do all baseline testing.
If you are looking to begin the process of improving driveability then headers become an important upgrade. If your goal is simply adding some HP, a non-restricive muffler and modern turbo will serve you better for the money spent. Of couse adding headers to that mix makes it all that much better.
Old 09-27-2007, 07:03 AM
If Rarly's SSi product turns out to fit right for most applications (it is still a developmental product to some degree) than they will be very good quality due to the expensive metals used, and they will heat the hell out of you in the winter compared to some heat exchangers. Brian is not going to stiff anyone, so you can buy from him without concern if a problem should arise.
Honestly though, I just took some old SSI designed headers off my car and got more power and better throttle response and less weight with B+B headers. They were in good shape after probably 15 years, but they have twice as much pipe length. I felt a difference in performance going to B+B from SSI.
A lot of the things that are said about SSI are true, they are good quality and give good heat. But B+Bs make power and decrease lag in my back to back informal comparison. And they weigh a lot less, probably 10-15 pounds less.
B+Bs also fit right the first time compared to a lot of the cheaper headers out there. People complain sometimes about them not lasting, so longevity is a potential issue, which is not the case with SSI.
If you just want a header without heat, then you can go the cheap route with the GSF/OBX/Schnell/Danske product which quite frankily all seems to be the same product. But the heat tubes make the install even more difficult according to some people, so I would go B+B for heat or SSI for heat and quality, at the expense of some performance.
I think SSI and B+B sort of have different strengths and are aimed at a different market. You have quality and really hot heat versus performance and less heat/quality. I live in Virginia so heat was only a marginal concern for me. But if it is below zero and you like to drive a 930, no question the SSI would be better and the performance gap wouldn't be noticed in that kind of weather because you would be producing a lot more HP in cold air anyway.
Old 09-27-2007, 09:41 AM
RarlyL8's Avatar
The current SSI 930 system is likely not the same as what you used.
The Y-pipe junction on the current SSI system is designed to optimise the exhaust pulse timing of the equal length primaries. The result is greater torque off-boost.
If I ever get time to work on my own car again I will dyno a set and show the torque curve.
Old 09-27-2007, 10:32 AM
skipdup's Avatar
How do the SSI's run? Are they like the travel like the euro style (around the front of the motor), like the early us (meet in the center), or another way completely? Anyone have a pic handy?
- Skip
1971 911T w/2.4
Old 09-27-2007, 11:39 AM
RarlyL8's Avatar
Check Out My Latest Project
Old 09-27-2007, 12:30 PM
I would have to agree...
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 09-27-2007, 12:49 PM
wcc wcc is offline
wcc's Avatar
I wanted a set of B&B or GHL but I didn't want to pay that price. I was just about to pull the trigger on a set of GSF but then I found a used entire GHL exhaust system in the PP Classifieds. I got the entire system for, what I think, a great deal. All I'm getting at is if you want the B&B or GHL just keep your eyes open in the classifieds and you might be able to get a good used set. Otherwise, I don't think you could have gone wrong with the GSF. Of course the SSIs on there is probably the absolute best way to go.
Bill
Old 09-27-2007, 01:50 PM
one thing to note here is this ssi set up has been developed from years of experience from john daniels of ssi. He is a no comprimise guy and he has a personal 930 and runs this setup on his car. I run it on mine and Brian is completing the entire kit up so it will be bolt on for you guys. so proven designs just putting the finishing touches on a great design. I assure you this will be the best on the market without question
Ben
Current project 73 914-6 Gt project rusteration 2.4
Reproduction 914-6 oil tanks, 1-5/8" 914-6 heat exchangers source call 2623647426 or email mbconsulting21 @gmail.com
Old 09-27-2007, 01:58 PM
A fellow Pelacanite
NathanUK's Avatar
DDDD, I think Danske headers are of the stock design, not short like B&B.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 09-27-2007, 02:40 PM
Well to complicate things further, Stephen of IA is saying that the 'danske' product is not the same as 'dansk', so who knows what is out there?
Old 09-27-2007, 03:28 PM
RarlyL8's Avatar
I believe that Dansk, the OEM for Porsche exhausts, is no longer in business.
Old 09-27-2007, 05:32 PM
Any idea when this setup will be available?
Old 09-28-2007, 04:28 PM
Brian will have them ready very shortly within weeks
Ben
Old 09-28-2007, 06:06 PM
Great! Please let me know.
1988 930S Flachbau
2007 BMW M5
2006 BMW M3
2006 Mitsu Evo
2007 Hummer H3
Old 09-29-2007, 12:28 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
