Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
mark '87 930's Avatar
If this ever happens to you... here's what I did.
I was checking my #5 plug as it was light in the past (if you recall) and I had recently changed the injector. (Plug is still lighter than the others)
Anyhow, after I re threaded the plug in, I fiddled for over an hour trying to get the plug wire clipped back on. NO GO. Insert all kinds of colorful adjectives here... Turns out the rubber insert inside the swanky Porsche supplied spark plug removing tool. It took me that long (please refrain from commenting) to finally clue in and look at the tool.. what a revelation I tell you.
Then I realized that , great, I figured it out but I still have to get the rubber out from around the plug..not as easy as it may sound.
SO I put some crazy glue on the tool, re-inserted it and twisting it slightly as I did. I waited a few minutes and then removed it. I had tried without glue and that didn't work initially.
So there you have it. Crazy glue, never leave home without it (and tie-wraps, duct tape, and relays)
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 09-27-2007, 05:10 PM
It sounds like you more than made up for your initial misstep with a brilliant solution. I'll keep this one in mind should I have the same problem. Bravo!
Andy Glass
'86 930 Kokeln IC, K27-7200, SC cams, GHL headers, Fabspeed muffler, Short R&P , misc other mistakes made...
Old 10-02-2007, 03:18 PM
930gt-40r's Avatar
If I got a nickle for every time I had done something less than par, I would be a rich man
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 10-03-2007, 04:56 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
