Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Smart quod bastardus
fredmeister's Avatar
Basically a shock works off viscous damping which is speed dependent. The shock therefore is a transient device. Now if you have less body mass to decelerate on the rebound with the same stiffness spring, then the ride will seem more bouncy unless you up the damping of the shock to compensate for it.
If you talk to Bilstein about mods they will make to custom tailor your shocks to your new torsion bars, it is amazing how much rebound damping they dial in.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 10-08-2007, 01:27 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
