total electrical cutout!
Who's car looks better on a flatbed? I was driving 40 mph and had a total electrical shutdown right in the middle of the road. No guages, lights, windows or radio. The starter does not turn, no fuel pumps firing, the hazards do not work and the electromotive crankfire led is not powered. Am I correct that all power runs through the ignition switch? Fuses are all intact. Cable running from battery to the starter was just a little warm when I went into the boot. Sidebar, I did install a new hi torque starter two days ago, could this have any impact? Not exactly what I had in mind when I went out for a spin... BTW, when you call the tow in make sure you request a flatbed with the additionad boards, this would've been impossible without them.
Tom
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 10-02-2007, 10:01 PM
Were you hearing any noises from behind the dash right before it shut down?
Old 10-03-2007, 03:33 PM
no noises, it cut out just like someone flipped a switch. Still have 12 volts in the battery, gonna look for an open circuit involving the new hi torque starter.
Old 10-03-2007, 07:49 PM
Just a quick update, replaced the electrical portion of the ignition switch (20 min, top screw is a real tight fit at the top), car fired right up. Wish they were all this easy. Thanks for the help gents!
Tom
Old 10-13-2007, 12:37 PM
