Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Trans seal question
It appears that I have a leak at the seal where the shifter rod enters the transmission on my '86 930. It resides under a rubber boot where the shift rod exits the tunnel. I cant find the seal in a parts diagram. Can anyone direct me. Also, is the replacement easy? The car is on a lift.
Old 10-06-2007, 07:22 AM
Check "Shifter Rod Seal". It is not all that EZ. There is actually a metal piece under the black plastic, rubber, you just have to be careful & work it out. Putting it back in is no problem. Here's the Pelican Tech article.
http://www.pelicanparts.com/techarticles/mult_shifter_rod_seal/mult_shifter_rod_seal.htm
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 10-06-2007, 09:06 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
