Smart quod bastardus
fredmeister's Avatar
79 930 crank pulley
Have a 79 930 and was wondering if the crankshaft pulley is also a harmonic balancer. It has the dual pulley for both the alternator and A/C drive, but I cannot tell from looking at it in the car whether it is a solid steel pulley or if it had a rubber disc to act as a typical harmonic balncer pulley.
Anyone know for certain whether it is a solid one piece design or not?
Thanks,
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 10-08-2007, 08:27 AM
7.0:1 > 11.3:1 > 7.0:1
My two groove 79 930 pulley was solid.
I also have an 89 930 two groove which is solid.
I noticed on both a 964 and a 993 motor there was rubber isolation which appeared to be for harmonic (edit) dampening.
Old 10-08-2007, 08:57 AM
It is not a harmonic balancer, the crankshaft and flywheel are internally balanced as a single unit.
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 10-08-2007, 09:19 AM
Thanks guys......just what I suspected.
Old 10-08-2007, 11:22 AM
