Send a message via AIM to wldrvr
996 GT 2 Carbon Ceramic Brakes
I help prepare a friends 911 GT 2 with the ceramic brakes. At all tracks with any downhills, the brakes are boiling the fluid after a couple of laps. Road America, Road Atlanta, even Heartland Park. Brake pads are disintegrating. I am using Motul which is about as good as it gets for dry boiling point, and have even tried flushing fluid between sessions. Still, heavy car and lots of speed trying to slow down at the bottom of a hill is killing us. Thoughts, suggestions, throw away and put on the standard iron discs and calipers?
Thanks,
Sean Cahill
Old 10-08-2007, 03:01 PM
what? me worry?
TimT's Avatar
Castrol SRF
Motul is good...SRF is way better.....
also... cooling... what are you doing about brake cooling?
who are those guys? <<< ( Butch Cassidy and the Sundance Kid)
Rent a GT3RS from us!! Call or e-mail.
Transportation and Track support
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
Authorised Haltech seller and installer
Authorised Unichip installer
BBS wheels
Fikse wheels
Redline motors oils
Swepco
1500 hp chassis dyno
Old 10-08-2007, 03:19 PM
Originally Posted by TimT View Post
Castrol SRF
Just using stock deflectors which are pretty elaborate on the GT2. Have not added any ducts or hoses as is a street car.
Old 10-08-2007, 03:50 PM
Max Sluiter
Flieger's Avatar
These are PCCB 1 right? The PCCB 2 in use on the 997GT3 Cups have much improved cooling vanes and do not exhibit the craking and longevity problems like the first generation PCCBs.
As was said, I would try removing any water shielding that is not necessary and adding cooling ducts to the front valence if possible. I have also seen electric fans be effective.
Or you could remove a few hundred pounds of weight with some carbon fiber bits.
-Flieger
(If your're using the brakes that much toboil the fluid, then you're going too slow )
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 10-08-2007, 08:19 PM
930gt-40r's Avatar
Unfortunatly there is not any large hunks of cast iron involved with the PCCB system that could soak the heat away from the pads and calipers. Would you consider switching out the PCCB rotors for a set of full floaters with aluminum hats to try to keep the weight increase down? I could be wrong, but the factory race cars (GT-2 track, GT-3 track etc...) still use the metal rotors.... I could swear I seen them glowing on the 997 GT-3 track car at the event I watched on TV.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 10-09-2007, 12:17 PM
930gt-40r's Avatar
That was mean, ouch!
Kris @ Tech9
86' 930/GT-40R Sold
Old 10-09-2007, 12:21 PM
Max Sluiter
Flieger's Avatar
Porsche Crest
I was just kidding, of course. If you aren't using the brakes, then you're not going fast enough.
Only Porsche 997GT3 Cup cars use the PCCB 2 carbon rotors in races like the Supercup. The 997RSRs and all 996 race cars use metal rotors. The PCCBs already have an aluminum hat, IIRC.
I think I saw that Elephant racing had brake pad backing plates with heat sink fins, but I think they were for early cars' brake set-ups.
As I see it, adding cooling ducts/fans is the easiest way to improve brake performance. Beyond that, switch to PCCB2 rotors with improved fins if the car does not already use the new design. This may become an option when rotor replacement time comes.
911S
Old 10-09-2007, 08:26 PM
Me like track days
Craig 930 RS's Avatar
Believe it or not..........
Have him shelve the PCCBs.
You can get better pads for steel rotors than the PITA PCCBs -- TRG has this kit, I have the pads for the steelies here at Rennstore.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 10-10-2007, 08:16 AM
A fellow Pelacanite
NathanUK's Avatar
This is what everyone does here in the UK that tracks their cars.
Some even do this for the road to avoid ever having to replace the expensive pccb's.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 10-10-2007, 11:54 AM
Adrenaline Junkie
Hayabusa's Avatar
-2008 GT3RS
Old 10-10-2007, 06:43 PM
Adrenaline Junkie
Hayabusa's Avatar
Old 10-10-2007, 06:47 PM
Me like track days
I see a sexy, overpriced, trouble-prone brake setup -
Old 10-11-2007, 07:45 AM
Adrenaline Junkie
Hayabusa's Avatar
Sad, isn't it! They are so beautiful!
Old 10-11-2007, 06:56 PM
Porschephd's Avatar
The system is junk. Both the 1st and second generations. We are seeing real issues now with the 997TT systems. After 5-6 track events consider 25K in your budget to replace the rotors and bads.
As suggested pull the system and look at Brembo and or swap the rotors to the steel version and run different pads.
Here is what I run on mine.
Stephen
94 3.6Turbo 6-speed AWD
Old 10-12-2007, 06:04 AM
Me like track days
Amen to that.
My brake pad customers (www.Rennstore.com) report so many problems.......
the switch is on to steel rotors.
Plus, this way you can use appropriate track pads as The Man intended - RS19 or RS29 Pagids.
Old 10-12-2007, 08:12 AM
Adrenaline Junkie
Hayabusa's Avatar
But, if you just switch to steels, why switch over to the Brembo's. What is the clamping difference between to Brem's and the Porsche calipers ,,, or did you have to switch for some other reason?
I thought because of Porsche's constant research that their caliper's were the best in comparison across the board?! I mean, obviously because they haven't yet got their composites down yet and they keep failing causing huge monetary pains in the arse does that indicate still that their calipers aren't there either?
Old 10-12-2007, 09:33 AM
Me like track days
Keep the factory 6 piston calipers and switch to steel - and you will be perfectly happy.
Calipers fine, their PCCB rotors.. not so much -
Old 10-12-2007, 09:45 AM
BoxxerSix's Avatar
A tad off topic Stephen but that's your 997 with the Dymag's on it correct? How do you like those carbon hoops? I bet they more than make up for the unsprung weight increase in swapping from pccb to steel rotors
The pccb rotor issue seems to have been known since track day one and has yet to be resolved, yet Porsche still claims their absurd price tag on the option. I know a couple local 997TT owner have brought their cars back in to the dealer for PCCB upgrades and sold the OEM steel setup, obviously not for track or uneducated in the matter. I feel bad for the C-GT owners who really track their cars, 15" carbons all around with center lock hat setups can't be cheap!
I have a cracked and disintegrated pccb v1 rotor from a 996 GT3 that I'm eventually going to turn into a wall clock. Seems fitting but what a waste right......
Adam Hennessy
Old 10-12-2007, 12:28 PM
Adrenaline Junkie
Hayabusa's Avatar
I would kiss that wall clock every night before bed!
Old 10-12-2007, 02:35 PM
Adrenaline Junkie
Hayabusa's Avatar
Still wondering why he switched to the Brembo's over the stocker's.
Do hear that sound? That is the black hole of money being pulled from your bank account!
Old 10-12-2007, 03:49 PM
