Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
965 using lots of oil
My 965 seems to be using more and more oil. I'm starting to keep a more detailed log, but it's feeling like a quart every 300-500 miles. There are no obvious signs of a leak in terms of puddles/drops on my garage floor. I'm not seeing a lot of smoking aside from upon start-up when the car has sat for a week or more and that goes away quickly.
Any suggestions for someone who is not mechanically inclined?
Frank - Menlo Park, CA
1991 964 Turbo
Old 10-10-2007, 07:28 AM
"I wuz the liquor..."
sand_man's Avatar
Take this for what it is: internet info, but I was told that about 1qt every 1,000 miles was "normal" consumption for a 930. Of course so many things can effect this, from climate, to the weight of the oil being used, to how the car is being used (track vs street), to the actual engine mileage.
-jeff
Old 10-10-2007, 08:16 AM
sand_man's Avatar
I think 1 quart every 300 miles is a lot if that's really accurate. FWIW, after about 600 miles, I start to notice that the oil level gauge has dipped slightly and that the reading on my dip stick is a tad lower.
-jeff
Old 10-10-2007, 08:17 AM
What oil are you using?
Charles Navarro, LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
'99 Boxster powered by Flat 6 Innovations; '10 Cayman S (DFI testbed)
Old 10-10-2007, 12:31 PM
mobil 1 - 15w-50
the other day, i put 2.5 quarts in to get my in-dash gauge at halfway. i drove about 120 miles yesterday. i already see the needle pushing down. it's lower than at the start of the day.
1991 964 Turbo
Old 10-10-2007, 07:23 PM
GO DAWG GO's Avatar
I think Porsche recommends 40 weight. My car seems to enjoy oil too. It will eat about 1 quart every 3-400 miles and has a couple of nagging small leaks. I have begun using straight 40 weight Castrol and actually added a block sealer to swell the timing chain cover seals. Engine runs well. I have thought about a re-seal but know its close to a top end job...Excuse to throw in some better cams and head work.
1 bad 930
Old 10-10-2007, 09:14 PM
Don't necessarily go by the gauge. Check the dipstick. Everytime I go by the gauge, I end up putting in too much oil. Usually the engine is hot but the thermostat hasn't opened yet. I try not to touch the oil level unless the oil temperature gauge reads about 9 o'clock.
No one recommends straight weight oils anymore. Porsche recommends 0w40, but if you've read any of the oil threads lately, I would take that recommendation lightly with anything but an under warranty new Porsche.
Old 10-11-2007, 03:05 AM
sand_man's Avatar
How many miles are on the car? You could always have a hot leak down test performed as well as a compression test.
FWIW, I run Brad Penn 20W-50 in mine.
-jeff
Old 10-11-2007, 03:13 AM
sand_man's Avatar
While we're on the subject of oil consumption, I remember reading in some of the other oil related threads that some of the normally aspirated SC guys claim that they had "zero" consumption in between oil changes!!! Is that even possible in an engine of this design?
-jeff
Old 10-11-2007, 07:09 AM
Wo ist die Rennstrecke?
DonE's Avatar
Charles is right - the indicator is more a quick guesstimate. Under accel, on an uneven surface, etc, the guage will be off.
On my last rebuild, my consumption went from 1 qt every 800 miles to 1 qt every 150 miles - all through the tail pipe and no obvious smoke. I did a leakdown and confirmed ring problem with an engine tear down.
On the new rebuild, with 1700 miles on it, it has used less than a quart total.
Old 10-14-2007, 08:18 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
