Me like track days
Craig 930 RS's Avatar
Also, gusseting not required for helpers with torsions
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 10-13-2007, 09:49 AM
Originally Posted by jbrinkley View Post
the groove is machined in by? Clint?
there is the option of sending yours in and having this done.
I think this could be done locally but if someone accidentally penetrates the body, you'd be in a bind
that is correct clint does machine them in and will do them on exchange basis. infact jerry has a core set for you guys.. there work spectacular on my car and the fronts are very cool as well. I believe he has 935 spring plates in the works as well
Ben
Current project 73 914-6 Gt project rusteration 2.4
914-6werkshop.com ,heat exchangers, oil tanks, etc
Old 10-13-2007, 02:55 PM
Jeff Alton's Avatar
I use Clints rear coilovers (no torsion bars). They are well made. Mine are coupled with custom valved shocks and I am very pleased.
Cheers
jeff@turn3autosport.com
997 S 4.0, Cayman S 3.8, Boxster 2.7, Boxster S race car, 996, 955 Cayenne TT, 958 Cayenne TT
Old 10-13-2007, 04:14 PM
Adrenaline Junkie
Hayabusa's Avatar
Originally Posted by mb911 View Post
rebelracingproducts .com is where they come from and his car is one our conversion turbo kit on his carrera
Thank you, Sir!
Old 10-13-2007, 07:01 PM
Adrenaline Junkie
Hayabusa's Avatar
Originally Posted by Craig 930 RS View Post
His sig sez:
87 911 3.2 with M&K turbo kit
I was probably asleep.
So, did Jerry use the dropped spindles for the front. I read that he was trying to prevent squatting,, but the car looks properly lowered over stock.
And, if he did go with the RSR fronts is the bump-steer kit required.
Is this the front with bump-steer addition showing?
I guess I am not sure what my total package should be, and I confess I haven't search around to in depth. I mainly got sucked in here, guys, forgive me.
Old 10-13-2007, 07:27 PM
Jeff Alton's Avatar
Yes that is the bump steer kit you see in the pic. If you use raised spindle struts it is required. I meaured my bumpsteer and ended up lengthening my SPR kit (the already long one) to get a good bump curve. Then I gussetted and welded it to the steering arm.....
Cheers
Old 10-13-2007, 09:58 PM
Adrenaline Junkie
Hayabusa's Avatar
Thanks, Jeff. It looks like an awesome setup that would transform the stock car into an all out performer. How will I know exactly what torsion size to go with though?
Old 10-13-2007, 10:35 PM
jerry only used the rears as long as me but may do the front as well
Ben
Old 10-14-2007, 04:40 AM
I don't have bilstein struts, so isn't gonna happen for a while, if ever. I keep telling myself I'm done with this car until it explodes. But a couple months go by here and there and I can't help but buy stuff for it.
it's a disease for sure
Old 10-14-2007, 05:30 AM
