coil over helper springs
My car had a serious squat issue and Clint recommended these.
I got them Monday and redid all the bars and lowered my car to where I wanted it. Probably took 8-10 hours with all the adjusting.
Anyway, I'm very happy with them.
I set the rear bars very low and then installed these and raised it up about an inch.
No more squat, and that was the goal. It rides the same as far as I can tell
Old 10-12-2007, 06:47 AM
Me like track days
Craig 930 RS's Avatar
There ya go. The right way to do it on a 930.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 10-12-2007, 09:48 AM
Wo ist die Rennstrecke?
DonE's Avatar
You cranked in about an inch using the springs? What size springs do you have?
Old 10-12-2007, 02:50 PM
Adrenaline Junkie
Hayabusa's Avatar
Is that a 930? Looks Carrera
Old 10-12-2007, 03:42 PM
Adrenaline Junkie
Hayabusa's Avatar
Once cleared up,,,, where can I get those for my 930? Front AND rear?
Easy stock available?
Old 10-12-2007, 03:44 PM
Me like track days
Those are rears only - mine are roughly similar
His sig sez:
87 911 3.2 with M&K turbo kit
Old 10-12-2007, 04:36 PM
rebelracingproducts .com is where they come from and his car is one our conversion turbo kit on his carrera
Ben
Current project 73 914-6 Gt project rusteration 2.4
914-6werkshop.com ,heat exchangers, oil tanks, etc
Old 10-12-2007, 05:10 PM
Can the replacement rear Sports that I just installed be retrofitted with helper spings?
Old 10-12-2007, 05:11 PM
David's Avatar
Sure, check out the Rebel Racing stuff.
2014 Cayman S
2011 Cayenne Turbo
Old 10-12-2007, 05:13 PM
ben, have you been drinking?
they 're 200 # springs, and yes I just set the rear bars down to 24.5 or so inches and used the coils to raise it up to 25 flat, it was very easy. In fact it took longer to set the front ride height than re indexing the whole rear.
But of course I have camber and toe issues in the rear since I sheared a toe bolt off with the impact. I'm trying to figure out who to take it to now. I have that snazzy home alignment booklet by Scruggs, and it's very complete, but i don't really want to get into all that.
Old 10-12-2007, 05:33 PM
DonE's Avatar
The reason I asked about the size of springs is that I have 100lb helpers and they are only "just" engaged. If I crank in anymore, the rear tires easily break lose and the ride is way too stiff in the back - almost feels unbalanced. Anyway, nice set up.
Old 10-12-2007, 05:52 PM
Jeff Alton's Avatar
Craig,
Why is the the "right way" as opposed to putting in an appropriate rate coil spring and the associated gussetting?
Why not toss the torsion bars all together?
Does the coil spring only add spring rate when the rear end wants to squat under acceleration?
Cheers
jeff@turn3autosport.com
997 S 4.0, Cayman S 3.8, Boxster 2.7, Boxster S race car, 996, 955 Cayenne TT, 958 Cayenne TT
Old 10-12-2007, 09:08 PM
My best guess is that right now these are splitting the load 50/50 between bars and coils. I've only driven 20 miles or so, after I get an alignment and make it over to a friends house with scales I'll be able to see exactly whats going on with the weight on the rear.
My car is probably heavier than yours Don, but I just went with what was given to me. I think Clint goes with a best guess regarding weight and engine and stuff.
You have a bigger bar and most likely a lighter car. (speculation)
It was very flat on boost, no more front end rising up and steering getting light.
I actually purchased from Ben who is selling these now also
Old 10-13-2007, 02:34 AM
have you???? the question was is that a 930
Ben
Old 10-13-2007, 03:36 AM
hahahah
the truck is showing up this morning with my grampa car
Old 10-13-2007, 04:21 AM
A fellow Pelacanite
NathanUK's Avatar
How do you fit those tubes to the shocks? I am guessing you have to weld them on?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 10-13-2007, 04:54 AM
there's a groove on the body that has a circlip set in it that the sleeve sits on.
Old 10-13-2007, 04:59 AM
A fellow Pelacanite
NathanUK's Avatar
Will my stock Bilsteins have that groove? Where abouts is it so I can check?
TIA Jerry.
Old 10-13-2007, 06:12 AM
the groove is machined in by? Clint?
there is the option of sending yours in and having this done.
I think this could be done locally but if someone accidentally penetrates the body, you'd be in a bind
Old 10-13-2007, 06:31 AM
Me like track days
I call it the right way because getting enough spring rate on a 930 torsion car is nearly impossible w/o helpers.
At any rate, the setup is a great solution for our cars.
Old 10-13-2007, 07:27 AM
