Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Alternator Belt size?
I have a 79 930 and the 10 x 710 belt seems way too tight. I have all of the shims on the inside of the pulley and still too tight, I am missing 2 shims, I only have 4 so don't know if 2 could make that much of a difference but I don't think so. I tried a 29 inch belt which works but is too loose with all of the shims on the outside.
So tomorrow I'm going to buy 2 more shims and a 10 x 725 belt which I think will fall in between a 29 inch and 710 (I think 710 is approx 28 inch and 725 is approx 28.5 inch). Why would my belt be different? Seems almost like I have a normal 911 pulley on there. Is the 930 crank pulley smaller than a regular 911? Wouldn't you want the 930 pulley to be bigger than the 911 for more cooling?
Car is also a European model, don't know if that would make any difference.
Old 10-18-2007, 07:04 PM
Well my car uses the 725 belt even though supposedly its supposed to use the 710. Guess it's either a weird grey market thing or someone put on a different pulley at some point. Guess I won't worry about it.
Old 10-22-2007, 03:16 PM
Brando
quattrorunner's Avatar
Mine is too long and has all shims inside. Is it possable the pully is worn or did autozone sell me a balt that is too long? I mean sometimes squeeks when the lights are on and i blip it.
Turbo powa!
1977 911s. it's cool
Old 10-24-2007, 03:37 PM
if it's too long you want all the shims on the outside so the pulley half will snug up against the alternator as close as possible and push the belt as high on the pulley as possible and tighten, I believe you should have 6 shims.
If you are using a belt from autozone it is most likely going to be in inches so probably not going to be quite right because when I went to the auto parts store (checker, autozone) belts were only available in .5 inch incriments. To get it perfect I would buy the 710 mm or the 725 mm, not sure which your car uses but it should be one of those.
Old 10-24-2007, 03:52 PM
A fellow Pelacanite
NathanUK's Avatar
The less shims between the pulley halfs the tighter the belt will get.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 10-25-2007, 01:52 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
