need pic - clutch linkage 930 transaxle
Im in the final stages of putting my 1984 ROW 930 'roller' back together. I have a long type 930 transaxle. Can someone send me some pics of the clutch cable, where it attaches to the transaxle, and pics of the clutch arm, so I can see any springs\helper springs, etc. My clutch cable has a slight bend in it, from the parts diagrams I think its supposed to but Im not sure.
theamsoilguy@hotmail.com |
OFF THE BOOST PIPE NOW...
Is this what you want?Don't forget that after you install it, you'll need to pop the arm to load the spring.
930s rule the wasteland
can you give a better shot how the helper spring mounts
1980 930 Turbo 1993 Corrado 1983 944 1984 944 2001 VW golf TDI |
Forced Induction Junkie
Here are some "before" pics. Maybe they'll help.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
resident samsquamch
While we're on the subject, does the clutch cable tube go over or under the the throttle linkage that sticks out of the side of the tranny? I have a new cable that I need to install and I noticed that the old cable tube (Bowden tube?) runs under the throttle linkage connection point and appears to be getting cut.
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP ![]() |
Mine had it above the throttle linkage.
resident samsquamch
THANKS FOR THAT!!! Okay I was mistaken, that's how mine looks. But that sharp edge of the throttle linkage seems to be cutting that black protective casing on the cable tube.
You can loosen the clutch cable at the transmission mount and twist the clutch cable to help clear the throttle linkage. There won't be much clearance, but it will help.
very nice!
I'm having trouble hooking up my clutch pedal cable. I'm finishing a rebuild and had the transmisson off and I have a new clutch cable.
Should the transmisson lever and helper spring be "popped" aft and should the pedal be up or down? I can't seem to make it work. Thanks. |
"Should the transmisson lever and helper spring be "popped" aft and should the pedal be up or down?"
The D Spring will load it aft, so not much choice there. When I replaced my cable, I started at the tranny and worked towards the pedal. Make sure you give it plenty of slack (ie. allot of thread showing at the pedal end via the clevis)! I made the mistake of not having enough slack and the end result was when you pushed the clutch pedal the throttle would stick! The problem was where the cable dives over the throttle rocker at the tranny it would stiffen when the clutch was pressed and bear down on the rocker holding the throttle at whatever position it was at! It was really one of those "Oh dear god" moments when I test drove it after the cable change. Also make sure you do not intertwine the clutch cable with the throttle rod inside the tunnel!
Rod... 2010 - 997 PDK, Black on Black, Daily driver. 1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony! |
When hooking up the cable to the arm, make sure you pull the clutch pedal up and keep it in place with something before hand, Once it's hooked on the arm, you can remove the pedal block.
Does it matter to go under or over the throttle linkage with the clutch cable ? I bought a new cable and I can not seem to get it loose enough (appears to be too short when going over the top). The "old" cable on my car went over the top but not sure whether the new one can.
Mark TURBO = Free Power |
Thread Tools | |
Rate This Thread | |
