Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
935TURBO's Avatar
Brakes upgrade......
I've got 996 TT big red calipers with adapters and 322 mm discs on my 930 SE and I'm still unhappy with the braking of the car......rear wheels are not enough braking and front are blocking on big braking......
So, is there a way to upgrade the master cylinder, or separate front/rear braking...?....
I've installed a manual "valve" with 4 position, but wich is only "stopping" +/- the brake fluid for the front.....but not sending more to the rear....
Does someone did something to improve that...?
Thanks,
Serge
Serge, Gentleman Driver
Cool...ready to go faster...as follow.....
http://www.club911.net/viewthread.php?tid=65004
http://fr.youtube.com/user/935TURBO
http://www.insonorisation.com
Old 10-22-2007, 02:09 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Do you have 996TT or 99TT Big Reds? The 993TT brakes have a 320 mm rotor IIRC. You can plumb in a manual brake bias valve to the front or rear brakes to adjust them. Also, check for kinked lines.
Old 10-22-2007, 05:01 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
David's Avatar
Pads can make a bigger difference than disks or calipers, what pads are you running.
2014 Cayman S
2011 Cayenne Turbo
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Me like track days
Craig 930 RS's Avatar
Stock rear brakes?
I'd bet you have way too much front bias, ie the front piston area way exceeds the norm.
You have the proportioning valve hooked to the FRONT brakes?!?
These are for the rears only --
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 10-22-2007, 05:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
935TURBO's Avatar
Originally Posted by Craig 930 RS View Post
Stock rear brakes?
Yes .....stock calipers....because, no way to fit correctly the 996TT calipers on rear.....as follow.....
FRONT
REAR
But, a lot of my friends told me that the 930's are often "blocking" on front wheels......
Old 10-23-2007, 03:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Me like track days
You might try 944 Turbo fronts on the rears - you need way more rear bias.
Ask Bill Verburg -
Old 10-23-2007, 04:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
A fellow Pelacanite
NathanUK's Avatar
You can get the 930 fronts on the rear with some swapping of parts.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 10-23-2007, 05:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Send a message via Yahoo to Lukesportsman
Doesn't Instant G sell a kit to bolt front and rears on? I have all intentions to run 996TT on front and rear. I've already own them and discussed this with Dr. Timmons with positive reviews. Have you thought of running dual MC/s with balance shaft to help free up adjustments. I second the importance of pad choice. I understand your thought pattern, but I've never heard of anyone using the "restrictive" style proportioning valve on the fronts.
BOL
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8
Old 10-23-2007, 05:37 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
