Best Way To Jack Up The Front?
Do we have a jack point up front? I need to get both wheels off the ground and install jack stands. What is the best and safest way to do this?
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 10-23-2007, 05:45 PM
Metal Guru
911nut's Avatar
I lift the back first, setting the jack stands on the torsion bar covers.
Then I lift the front on the center of the crossmember and set jack stands on the control arm front mounts.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 10-23-2007, 05:57 PM
A fellow Pelacanite
NathanUK's Avatar
I put my axle stands on the torsion tube covers on the front arms.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 10-24-2007, 01:24 PM
wcc wcc is offline
wcc's Avatar
I use the AC condensor protector bar to lift up the both front wheels. Then I support the front with jackstands at the torsion tube covers like NathanUK.
Bill
Old 10-24-2007, 04:56 PM
