Alan L's Avatar
Bleeding fuel supply
My 930 has arrived on a boat. It wont start. It coughed slightly then died. Not sure if it had enough fuel. Fuel gauge close to E. Put fuel in. But does it need priming. My SC requires lifting the air plate til the injectors load up. How do we do similar with the 930 - or what is needed if it has run dry on fuel.
Alan
Old 10-23-2007, 11:12 PM
Gently move the ignition switch toward start. Just before the starter engages you should hear the pumps running. Hold the switch there a few seconds before starting. It's a recirculating system with a regulator, so this should be all the "priming" you need. Others feel free to correct me if I'm off here...
Andy Glass
'86 930 Kokeln IC, K27-7200, SC cams, GHL headers, Fabspeed muffler, Short R&P , misc other mistakes made...
Old 10-24-2007, 12:36 AM
A fellow Pelacanite
NathanUK's Avatar
We have been discussing pump behaviour on Rennlist.
To make sure the pumps are on you can simply disconnect the connection going to the CIS flapper plate. This will make the pumps come on if the ignition is on.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 10-24-2007, 01:34 PM
Alan
You are correct. To bleed the fuel injection you need to manually move the air flapper till the injectors squeal. Just like the SC.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 10-25-2007, 05:59 PM
Alan L's Avatar
Thanks guys - I followed the first advice and expected it to prime itself. It finally did, after a lot of coughing and spluttering and starter motor cranking. Finally fired on one or two, enough to turn it over without starter motor. Slowly the others came to life. I think I will try depressing the air plate next time.
Thx
Alan
Old 10-25-2007, 06:40 PM
