-   -   new clutch slips under boost (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/374529-new-clutch-slips-under-boost.html)
h20cooled7 10-28-2007 05:08 PM
stock disc ,lightend pressure plate new flywheel and adjusted to factory repair manual but im getting slippage under boost. what the f@$#!!!!!!!! my car is modified but not over 500 hp. should i take all the play out of the linkage ? does any1 have any suggestions or am i ganna be ripping this thing back apart to put a heavier pressure plate in it?
9dreizig 10-28-2007 06:12 PM
make sure that when it's out there's no tension in it,, just for a sanity check,, then adjust from there. Are you sure you've got the throwout lever on the right spline? usually youv'e got a choice of two.
David 10-29-2007 06:35 AM
I had the same problem with my new clutch until I realized it went out of adjustment shortly after I first used it. Reseting the clearance on the adjusting bolt under the tranny fixed it right up.
h20cooled7 10-29-2007 07:53 AM
its the pull style clutch . I took all the play out of the small paw . theres no index notch on the shaft, I can put it where ever I want. and adjusted the cable to spec .045 and then .040 .I'll recheck tonite.
AngM018 10-29-2007 09:55 AM
The shop manuals state to be sure to re-adjust after break-in because it will fall out of spec on first use.
NathanUK 10-29-2007 04:28 PM
Post some pics of the tubes adjustment, omega spring & the adjusting bolt.
h20cooled7 10-30-2007 07:00 AM
ok ,I'll try to post thursday thats when I'm gonna readjust. Thanks for all the feedback!
h20cooled7 10-30-2007 04:49 PM
how often do you guys adjust your clutches?
h20cooled7 11-03-2007 09:29 AM
readjusted and seems to be fine, how can i adjust my pedal height ?
AngM018 11-03-2007 11:01 AM
What do you mean by height? how far it goes to the floorboard or how far away it is from the floorboard?
If it has to much travel, there is a stop on the floor board that can be adjusted. Just be careful there isnt to much travel or you will pop the throwout bearing off the arm or worst (dont ask me how I know this, lets just say it caused me to drop the engine again)
If it is not close enough to the driver, what I did was use a block of wood to hold the pedal up while I adjusted the clutch.
h20cooled7 11-04-2007 02:58 PM
how much horsepower is to much for the stock set up?
AngM018 11-04-2007 08:30 PM
Stock=rubber center. Those things can go at any moment. I upgraded to a spring center with lightweight aluminum pressure plate. better to be safe than sorry.
h20cooled7 11-05-2007 05:13 AM
i did the same thing but its still slipping . i pulled up a post and some1 said dont use a aftermarket clutch cable because they are to short,thats what i have. it kinda makes sense because i dont have much adjustment at the front of the cable. i also might have close to 450 to 500 hp . stage 2 ******** tune. im just wondering if the clutch setup can handle this much hp?
NathanUK 11-05-2007 12:59 PM
I learnt along time ago not to bother with so called cheaper parts.
Porsche there is no substitute.
Post some pics.
h20cooled7 11-05-2007 05:07 PM
ok Ill try the porsche cable and let you know what happens
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
