930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Question new clutch slips under boost
stock disc ,lightend pressure plate new flywheel and adjusted to factory repair manual but im getting slippage under boost. what the f@$#!!!!!!!! my car is modified but not over 500 hp. should i take all the play out of the linkage ? does any1 have any suggestions or am i ganna be ripping this thing back apart to put a heavier pressure plate in it?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 10-28-2007, 05:08 PM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
make sure that when it's out there's no tension in it,, just for a sanity check,, then adjust from there. Are you sure you've got the throwout lever on the right spline? usually youv'e got a choice of two.
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 10-28-2007, 06:12 PM
David's Avatar
I had the same problem with my new clutch until I realized it went out of adjustment shortly after I first used it. Reseting the clearance on the adjusting bolt under the tranny fixed it right up.
2014 Cayman S
2011 Cayenne Turbo
Old 10-29-2007, 06:35 AM
h20cooled7's Avatar
its the pull style clutch . I took all the play out of the small paw . theres no index notch on the shaft, I can put it where ever I want. and adjusted the cable to spec .045 and then .040 .I'll recheck tonite.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 10-29-2007, 07:53 AM
The shop manuals state to be sure to re-adjust after break-in because it will fall out of spec on first use.
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 10-29-2007, 09:55 AM
A fellow Pelacanite
NathanUK's Avatar
Post some pics of the tubes adjustment, omega spring & the adjusting bolt.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 10-29-2007, 04:28 PM
h20cooled7's Avatar
ok ,I'll try to post thursday thats when I'm gonna readjust. Thanks for all the feedback!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 10-30-2007, 07:00 AM
h20cooled7's Avatar
how often do you guys adjust your clutches?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 10-30-2007, 04:49 PM
h20cooled7's Avatar
readjusted and seems to be fine, how can i adjust my pedal height ?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 11-03-2007, 09:29 AM
What do you mean by height? how far it goes to the floorboard or how far away it is from the floorboard?
If it has to much travel, there is a stop on the floor board that can be adjusted. Just be careful there isnt to much travel or you will pop the throwout bearing off the arm or worst (dont ask me how I know this, lets just say it caused me to drop the engine again)
If it is not close enough to the driver, what I did was use a block of wood to hold the pedal up while I adjusted the clutch.
John A.
Old 11-03-2007, 11:01 AM
h20cooled7's Avatar
how much horsepower is to much for the stock set up?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 11-04-2007, 02:58 PM
Stock=rubber center. Those things can go at any moment. I upgraded to a spring center with lightweight aluminum pressure plate. better to be safe than sorry.
John A.
Old 11-04-2007, 08:30 PM
h20cooled7's Avatar
i did the same thing but its still slipping . i pulled up a post and some1 said dont use a aftermarket clutch cable because they are to short,thats what i have. it kinda makes sense because i dont have much adjustment at the front of the cable. i also might have close to 450 to 500 hp . stage 2 ******** tune. im just wondering if the clutch setup can handle this much hp?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 11-05-2007, 05:13 AM
A fellow Pelacanite
NathanUK's Avatar
I learnt along time ago not to bother with so called cheaper parts.
Porsche there is no substitute.
Post some pics.
Old 11-05-2007, 12:59 PM
h20cooled7's Avatar
ok Ill try the porsche cable and let you know what happens
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 11-05-2007, 05:07 PM
