Rory Mckenna's Avatar
Can you fit 9" fuchs on the front of a 79 930?
Can you fit 9" fuchs on the front of a 79 930, or will it have issues?
I know youca fit 8's but I was wondering if you go bigger than that on the front will you have to ahve a custum pair of wheels made up to allow for the things to fit under there with out issues.
Thanks in advance!
Old 10-29-2007, 08:01 AM
no one has the answer.. I guess I'll have to borrow a wheel from someone and try it out.
Old 10-29-2007, 01:21 PM
Well yes it is possible. Whether or not you'll have to change to a smaller spacer is the real concern. What tires are you planning on running?
Old 10-29-2007, 01:48 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I installed a rear 9'' on the front and had tire rubbing issues with the left front tire and fender on right hand turns. There are no spacers to remove.
Old 10-29-2007, 05:08 PM
I will have to see if i can get a wheel and check it out.
Thanks for the input guys.
Old 10-29-2007, 05:12 PM
CT944's Avatar
not sure if i have 9" on front, but i am running 245-40-17's.
2007 997 TT
1992 500e
Old 10-29-2007, 05:41 PM
Crotchety Old Bastard
RarlyL8's Avatar
I'm sure Bill V has that info on his spreadsheet.
Old 10-29-2007, 07:11 PM
I know 9's will fit but I am wondering if 9" fuchs will clear. Thanks guys!
Old 10-30-2007, 04:00 AM
An early turbo should have spacers on the front.
A Ruf 9" wheel has a few more millimeters of offset and fits.
There is a little variation from car to car, and from tire to tire, so you may just have to try it.
JR
Old 10-30-2007, 05:33 AM
Thnaks, I have a buddy that has some 9's. I'll see if I can borrow one or both of them and give it a try.
Old 10-30-2007, 05:46 AM
Dai Dai is offline
Javadog, I just bought Ruf 9" wheels for the front and I hope it will fit. Are you running Ruf 9" wheel for the front now? If so, what tire size are you running? I'm planning on running 235 tire due to fear of rubbing.
Old 10-30-2007, 05:48 AM
