Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
930 oil leak
I have a 1987 930 that's leaking oil below the number six cylinder. The oil thermostat was leaking and I replaced the oring on it but there's still a leak coming from that same location. Does anyone have any ideas what this leak could be. The oil cooler is not leaking.
Old 10-31-2007, 07:18 AM
"I wuz the liquor..."
sand_man's Avatar
Many of the leaks start on top and make their way down. There is an oil pressure sensor that is a common leak point. It's located not far from the engine oil thermostat...near the crankcase oil breather cover - in between cylinders three an six.
-jeff
Old 10-31-2007, 07:32 AM
I forgot to mention that I replaced it also.
Old 10-31-2007, 07:58 AM
Adrenaline Junkie
Hayabusa's Avatar
What? 930's don't leak!
Old 10-31-2007, 09:53 PM
dewolf's Avatar
Had the same issue and it turned out to be a barrel gasket
Old 10-31-2007, 10:43 PM
rotorhead's Avatar
Had the same issue +1 for the barrel gasket
here is the thread (with photos) where I worked it out
Help me find the source of this leak
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 11-01-2007, 04:15 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
